Question about Garden
Ryobi petrol strimmer model RCT 2800 refuses to start
Need a copy of the instruction manual or the settings for the carburreter jets.
Malcolm
  • Anonymous Jan 12, 2009
    I replaced the fuel lines, was then unable to start the engine
Has anyone got a spare cord Pulley for a Ryobi RCT 2800C . The engine seized but I have freed it and now see the plastic spines are damaged on the pulley. I understand the part no is Hayter 683856.
Posted on Aug 03, 2013
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: what are the carb settings for ryobi rct 2800 cb trimmer ,they have been adjusted so the correct position of the screws is not known
Hi peter beaufoy...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Posted on Sep 29, 2012
  • 474 Answers
SOURCE: petrol strimmer good spark but wont start
if it ran fine then it quit it is more likely the pick up tube in the fuel tank
Posted on Sep 14, 2009
Hi what is the ratio of oil to petrol on the 26cc petrol strimmer
Usually on a 2 cycle engine I will use 32-1 mix. Most engines will be fine if you get a name brand oil like Ryobi, Still, Echo, etc, with a pre-measure area made on top of the bottle. Follow instructions (usually 2.6 ounces per gallon.)
Feb 25, 2015 | Garden
Ryobi rlt 30 cesa petrol strimmer will not start
Keith you have got to make sure the gap is right between the coil and the magnetic flywheel. Use a buisness card to set the gap and make sure the coil is on the right way.
May 14, 2014 | Garden
What are the carb settings for ryobi rct 2800 cb trimmer ,they have been adjusted so the correct position of the screws is not known
Hi peter beaufoy...
Bud
Sep 20, 2012 | Ryobi Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
Ryobi strimmer petrol wont start
check spark plug. hT lead.
Jun 30, 2010 | Ryobi Garden
I have been given a ryobi 306rt petrol strimmer. It starts and then cuts out, I'm not sure of the exact settings as to how you start it up and keep it runnng. Any help would be apprciated.
To give the inital fuel needle mixture settings i would need to know the type of carb. on the unit ie. zama,walboro ect. it should say on the carb.,it may take a little hunting for. Second check all the fuel lines running from tank to carb. checking for craks or breaks.
Dec 26, 2009 | Ryobi Garden
Petrol strimmer good spark but wont start
Sep 14, 2009 | Garden
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
1,301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
