Question about Keyspan Computers & Internet
Light flashing, connected to port1, device info says port 1 available
Keyspan driver is installed (Mac OSX 10.4.5) ibook. Connect device to Port 1, light flashes for approx 1 minute, device info indicates port 1 is in use but when the light stops flashing on the Keyspan, the device info blinks back and forth between port 1 9600 and port 1 available. It finally stops on Port 1 available. However, I am connected through port 1 so it doesn't make any sense. If I change the physical connection to Port 2, the light on the Keyspan flashes on and off for approx 1 minute and in the Assistant under Get Device Info, the same situation occurs but when the light stops flashing, the info states Port 1 available. I have uninstalled the driver, trashed anything related to Keyspan, reinstalled and the same situation occurs. Any help would greatly be appreciated. I'm ready to throw it out!
secretgeek50
  • 57 Answers
SOURCE: windows doesn's recognize camera, device manager says no driver
Hi -
Have you tried another USB port? Sometimes, they can act goofy.
Also be sure your anti-virus isn't blocking any part of the installation.
Here is a link to the Samsung troubleshooting guide for your camera.
You can probably download the most recent driver from that website as well.
Perhaps they have a better or newer version than what came prepackaged
with the camera (just because a camera is a new purchase does not mean
the software it came with is the most updated).
http://tinyurl.com/5zsvwd
I run WinXP home edition, so I am not familiar if there are any differences in the professional version regarding software installation....
Posted on Dec 17, 2008
  • 55 Answers
SOURCE: Drivers required for keyspan USA-9WG SERIEL TO USB
Try the following link:  Model USA-49WG Keyspan Driver - Windows 98, 98 SE, Me, 2000, Vista (32bit), XP  (exe - 6 Mb )
Posted on Apr 26, 2009
jrwoodlock
  • 19 Answers
SOURCE: My iBook wont connect to my Linksys wireless G router
try removing the passkey and security on the linksys
then enable reverse authenication, by allowing only specific MAC addresses to access the router. ( MAC FILTERING ) ONLY ALLOW
then add the MAC addresses of your IBOOK and what ever else you have..
simple and secure :)
Posted on Aug 21, 2009
clokker
  • 253 Answers
SOURCE: Hi, Foxconn m61pmv = 1 port1 L, 2 aud gnd, 3 port1
get the manual from here
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=M61PMV&TypeID=en-us0000001
Than go to the side number 22
there it is...
Posted on Feb 03, 2010
  • 42 Answers
SOURCE: LS2208 displays no light
If the scanner is on a USB extension, they can be underpowered and will show up in the device manager but not work. This device like to be connected to a USB cord no longer then 4 ft or so.
Posted on Feb 23, 2010
To connect a ion PIC2PC ot a imac Mac OSX with in the USB-port. I have installed CrossOver and drivers from the packet, it is connected, but my mac cant
Hi. You won't locate the scanner using Finder - the same as you can't find a printer.
Scanners normally only show up when the software that uses them calls for them. I think, however, the problem may be Crossover. Crossover is a brilliant application and it runs most windows apps without too much hassle - it does appear though that it has problems talking to USB connected devices.
I have spent an hour or so this even ing trying to connect an energy recording device via USB but the windows software can't seem to find it.
Jan 14, 2012 | Apple iMac Computers & Internet
Can't set up to use.
this should work with OS 8.1 or greater, as long as your slot is 5v and not 3.3v but there are serial printer port driver issues, but nothing other than the usual, see below http://www.keyspan.com/products/sxpro/homepage.2.reqs.spml http://www.keyspan.com/products/sxpro/homepage.2.compat.spml
Oct 02, 2007 | Keyspan SX Pro (SX-PRO4) Serial Adapter
I use a Mac G3 Wallstreet Powerbook with OSx. Does OSX talk SCSI?
It will only read devices connected unless there is a problem with the scsi port. Also be aware early scsi needed termination to be read.
Apr 08, 2010 | Apple Power Mac G3 Desktop
Can not connect my US-4A on my network.
Hello, I finally solved my problem by reset the device.
Oct 16, 2009 | Keyspan USB Server US-4A (d47710) Print...
Aug 21, 2009 | Linksys Wireless-G Broadband Router
Can't add printers to Mac
Can you install them individually (i.e. connect only one printer with a single cable to the USB port)?  If you can and then connect them both through a USB hub you may be able to see them both in the printer setup and select the one you want when printing.
Jun 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
I need a Vista driver for the USA-19QW Serial Adapter
I have an old 4-port Keyspan serial device that also doesn't work with Vista.  Unfortunately Keyspan didn't provide Vista drivers for some of the older USB to Serial devices before they were acquired by Tripp-Lite, so you will probably need to get a replacement (Keyspan usa-19hs has Vista support, that one works for me).  The support page for Keyspan USB devices is here: USB Connectivity & Device Servers
Apr 20, 2009 | Keyspan (USA-19QW) Serial Adapter
Just repaired g3 ibook. Hard drive needs formatting, as it has xp loaded on it. Ibook starts up, boot tone, proceeds to load, then screen has a file in the center of screen with the osx finder square face...
With the OS X Installer CD in the drive, try booting your mac and holding down the option key immediately after you hear the start up chime. This will (hopefully) load a firmware boot loader that will show available start up discs. Hopefully the OSX installer will show up as CD Icon. Select the Icon with your mouse or keyboard and press enter to start up with the Installer CD. From the installer you should be able to erase and format the drive as Mac OS Extended before installing OS X.
If the computer still won't boot from the CD double check that it is a retail OS X installer CD. If your CD has "software restore" or "ibook restore" or any other varient of restore written on the label; or if it names a particular model such as "ibook install" or "imac install" it is not a retail copy and may not be a bootable disc. A retail copy will only name the version of the operating system followed by the word install written on it's label and usually have a brief instruction on booting from the CD by holding the C key at startup.
Hope this helps, let me know what happens.
Apr 03, 2009 | Apple iBook G3 Mac Notebook
Failure to read USB connected storage drives
What I have seen with some computer models, is that the USB port cannot deliver enough current to run some devices.
If possible, use an external drive with its own power supply and see if it will work. Most likely it will.
Also, try a powered USB hub. I found that most of the time, a powered USB hub solved many problems with having enough power for some external USB devices.
Jerry G.
Jul 26, 2008 | Apple iBook G3 Mac Notebook
Usb to serial adapter question
Try installing the Wacom USB drivers on the Mac. As I understand it, this adapter is designed to interact with devices that have their own serial drivers installed--such as a PDA, cell phone, camera, etc.--not necessarily with an input device, such as a drawing tablet, game controller, or pointing device. YMMV.
Dec 09, 2007 | IOGear (G-UC232A) Serial Adapter
Computers & Internet Logo
74 people viewed this question
Top Keyspan Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Keyspan Computer and Internet Expert? Answer questions, earn points and help others
