Question about Gateway Computers & Internet
Need to uninstall the Windows Service Pack 3 which makes the DNS client service not functionable - want computer restored to the way it was prior to that Windows installation. thanks .
  • ckosuda Nov 08, 2008
    that did it - thanks so much!
Have you tried the to restore it to a set point from whenever before the SP got installed? Start, Programs, Accessories, System Tools, Stsrem Restore
Posted on Nov 07, 2008
Windows xp professional service pack 3 intel pentiun p 6200 2.13ghz ram 3gb cant launch gta 4 erorr 0xc00001325
May be its problem on service pack 3 installation. please uninstall sp3 and again install.
Aug 08, 2011 | Computers & Internet
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
I need product key for window vista
Products that are acquired from retail would have been provided customer support resolvements. Refering with technical support to restore malfunctions is a methods available. Altemately refering with customer support as means to capture impressive resourcefulness availabel to the product acquired is means to resolvment. Once a product is malfunctioning sometimes requires evaluation ascertaining that is beyond repair restore feature functionalities. For example, retail has the newer versions of the brands aready acquired. Windows 7 has new improved versions also much effective at resolvments. Recogniseable traders of computer resources includes physical stores target, best buy wal mart also available on the internet websites where convenient network structures makes productiveness. Windows 7 softwares cost $199 dollars to acquire at retail. Evaluate the computer prior to acquiring especially would require a new computer to attain productivity rather than the softwares that also involve technical installation fees only when functionality can be attained.
Apr 09, 2011 | Microsoft Windows Vista Home Premium with...
It is not a problem but a question. Can I install Outlook in windows 7 and will ntelos support it as my mailbox?
Yes, but you will need to make sure if the version of Outlook that you have is comaptible to windows 7.
Officially only Outlook 2003 and Outlook 2007 are supported to run on Windows 7. This is similar to Windows Vista which also did not support earlier versions of Outlook. You can install a version prior to Outlook 2003 on Windows 7 though but there are several issues which you could encounter.
In addition to these version requirements, even with Outlook 2003 and Outlook 2007 there are several compatibility issues which you could encounter on Windows 7. The most critical of these issues have been taken care off in prior service pack releases. So before starting Outlook on Windows 7, make sure your first apply at least Service Pack 3 for Office 2003 and Service Pack 2 for Office 2007.
Hope this will help...Your response is very much appreciated...
Jan 24, 2011 | Computers & Internet
My pc stoped after 30 min
Dual Channel supported up to 4GB DDR2 533/667 MHZ [XP will only see 3 GB x86 / 32bit]
Freezing is most likely caused by a faulty hard drive, or faulty RAM. I would test both for faults.
Jun 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
Just updated to service pack 2 in windows xp. Now when I restart my computer it won't start up. I've used sys restore but still the same. I'm online now in safe mode
uninstall Service pack 2 you can uninstall it from start - control panel - add or remove programs, make sure you have the show updates checkbox checked.
Oct 13, 2009 | HP Computers & Internet
I wnt to install service pack 3,bt dnt hv d product key...plz tel
The service pack 2 and 3 full client dowloads are available from Microsofts website. The only key you need is for your Windows OS not the service packs.
Jul 29, 2009 | Microsoft Windows XP Professional With...
Network connection lost since sp3
Go to Add/Remove Programs in the control panel.
Next find Service Pack 3 and select "Uninstall"
This will roll your PC back to XP SP2, if you had SP2 installed prior to installing SP3.
See this link from Microsoft:
http://support.microsoft.com/kb/936929
Scroll down till you come to "uninstall info for windows service pack 3 release candidate'.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 06, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lan Network Problems
Hello: What I would say is: go to microsoft update and make sure you have all the updates for your OS.
Then; read the posting (below) from someone who had the same issue:
stacemarie wrote: "XP SP 3 updates some networking sharing system LAN files that cause some configurations to become unaccessable on the workgrouped networks. We cannot - even ping - the network addresses after installing - so it was an uninstall and do a system restore to get to the original good working state of the clients.
Microsoft needs to come up with a patch to fix this as we are seeing more and more networked clients having these connection and sharing problems."
Do you understand the above?
Let me know if you do not know how to unistall SP3 and do a Restore...
Jun 24, 2008 | LanReady LA1000+ Network Adapter
Computers & Internet Logo
24 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
