Question about Optimus STA-795 Receiver
Only 2 channels working
Neither AM nor FM has ever worked, but I only wanted to use my turntable so it didn't matter. Had a tech look at it, he said only 2 channels were working and hooked up to those channels. I bought a new receiver but it would not power my speakers. That is the important point...I want to keep my speakers...12" woofers, 8" midrange, 3" tweeters. Man at Radio Shack said older turntables would not work with new receivers. I've talked to everyone in town, get a different info every time. Please Help. P.S. I have the user's manual and will send Xeroxes or fax.
    President:
  • 3,130 Answers
If your new reciver does not have a turntable input, you can purchase a phono preamp and simply plug the turntable into the preamp and the output of the preamp to an aux or tape input of the new reciver. they should have it or be able to get it at radio shack. Or look up online or build one as I had to do as im a cheap skate, but I know what I have now..Check this out. i included the preamp i built so i can still use my collection of vinal with my surround sound system. Good luck and please dont forget to rate this thread.
Posted on Oct 19, 2006
  • Larry  Dillon
    Larry Dillon Oct 19, 2006
    Oh by the way it uses a nine volt battery and mine has lasted over a year so far.
  • Larry  Dillon
    oops sorry you need two of these circuits to use a stereo pickup.
Turntable won't turn pyle pro
Are you sure that the motor is actually spinning and if it is there is a belt that drives the capistan drive
Apr 19, 2014 | Pyle Pro - PTCDS2UI - Classical Turntable...
When playing my turntable then music only plays out of one speaker
It may be a bit late to start talking, but you need to narrow down the problem. It could be all manor of things, but start by breaking the problem down.
Try the turntable in another known working amplifier. Does it work ok? If so the problem is not the turntable, but another part of your setup.
Try the following :
First of all, try a clean source such as a cd player. Does that come out of both channels ok? If so, your amplification is ok.
Is the the Turntable going into a mixer? Try another phono channel of the mixer.
Tried all channeles and still got a problem? Try another mixer as the master output of the mixer could be faulty.
Still a problem? Try your mixer in to another input of the same and of another amplifier? Is there still a problem? Well you have tested your main equipment, so now you can conectrate on the deck.
Get another headshell with another known working cart and install them into this deck. Still a problem?
Beyond this you need a little more expertise and I'm unaware of your technical abillities. As a matter of safety for yourself and your equipment, you should take it to a professional to have it repaired.
Feb 01, 2014 | Technics SL-1200MK2 Turntable
I am getting extremely faint sound from the left channel while playing vinyl. I have swapped all wires and cables left to right and back and the problem remains the same. The only thing I haven't tried is...
If you switch the cables so the left channel plays into the right of the amp and the sound stays dead in the left channel of the amp it's not the cartridge that is at fault by your amp. Amps have a magnetic cartridge pre-amp built into them for turntables. This can go faulty, but won't effect any other device (CD etc). Most of these pre-amps are a single IC. Which will need to be replaced.
Oct 18, 2013 | Technics SL-1210M5G Turntable
CDJ-800 Mk1 No sound output!!!
Not true! CD channels don't require a pre-amp and the cartridge for a turntable does. I suspect that when the power went off the mixer was still on, so that when power was restored it came back on. However this resulted in a surge inside the unit. Magnetic cartridge pre-amps are often very sensitive to this kind of thing and will sometimes fail, while everything else works fine. This would result in no sound from the record decks, but sound from CD players etc.
Apr 13, 2013 | Pioneer CDJ-800 Turntable
Lost all radio stations on my Sherwood RX4030R
It certainly sounds like the main tuner has failed, if IC301 does that function I would replace it and see what happens.
May 25, 2017 | Sherwood Audio Players & Recorders
Blue screen. Won't get any channels, or picture. Tried programing. Didn't work
It sounds that the tuner is faulty. Befror confirm it, a through checkup is necessary. Seek tech support.
May 24, 2012 | Prima C2012 TV
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
Record only plays through one speaker
If it works on Channel One it is NOT the TT. It's a mixer problem. Define the mixer and what else works or doen't work. have you tried another device on Channel 2?
Apr 30, 2010 | Technics SL-1200MK2 Turntable
Old Turntable Philips
You may have a bad stylus (needle), it can cause just that type of problem. Find a service center near you and see if they can get a replacement for you. They are very easy to replace, but very difficult to find.
Hope this helps.
Dave
Jun 30, 2008 | Audio Players & Recorders
171 people viewed this question
Top Optimus Audio Players & Recorders Experts
Marvin
Marvin
Craig Butler
Craig Butler
Ben Armstrong
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
