Labgear psw123 diplex satellite & tv/fm/dab socket
Please can you help me no fitting instrutions
  • 374 Answers
SOURCE: combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Posted on Sep 23, 2008
SOURCE: My Teac TH300 MkII DAB
have you plugged a dab aerial in to the back
Posted on Oct 26, 2008
  • 374 Answers
SOURCE: receiver 625`tv 2 fuzzy
4647cb4.png Okay if you have a seperator you should be connected with the ch21-69 port running into the diplexer as above. Outside on the second diplexer the uhf/vhf port should run to the second tv. The sat port on this diplexer should be ran to the ground block and then to the dish. Assuming this is correct we should check the connectors to ensure they are made up properly. The white dielectric should terminate flush with the inner most part of the connector where the wire enters the connector. Ensure that all of the dielectric has been removed from the center conductor at all locations and that no strands of the metal braiding has wrapped around or come in contact with the center conductor as this will cause the same issue you describe. If there are any barrels in the cable run and or you are using a wall plate ensure that they are high frequency barrels. Most will have a red or blue center on them the clear or white ones are low frequency. Ensure that your center conductor is no longer than a 16th beyond the end of the connector. Check the modulation on the receiver for tv2 and make sure it is on 60 air or 73 cable and that the tv2 is set the same. To check the modulation press menu 6-1-5 on the Dish remote. This can be done at either location. If all this is good we may need to consider the distance ran from TV1 to TV2. Also any breaks in the line will cause a decibel loss degrading the signal so if there are mirror images are barrels in the run it may be causing this issue as well. Lastly lets check to ensure that the port on the receiver is not generating the issue. If you connect the cable that is on the 3-4 out on the receiver to the 21-69 out and tune TV1 to the station you have TV 2 set to you will be able to see if the picture is clear from the port of the receiver. You can also run the cable that was originally on 21-69 out to the 3-4 out on the receiver and change TV2 to ch 3 to see if the issue still exists. The final way to check to see if the TV2 is faulty is to ru a line from the 21-69 out on the back of the receiver directly to tv2 inside the home so you will no the are only to connections and no breaks in the cable. If this last one produce the same fuzzy picture after all other steps the TV is faulty. You may try the opposing setting to see if that clears it up e.g. going from 60 air to 73 cable or vice versa. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
Posted on Nov 03, 2008
SOURCE: FM radio tune with fm antenna on a305-s6857
go to sound options.. dissable built in mic and enable fm radio. make sure antenna is plugged in
Posted on Jan 03, 2009
welcomejee
  • 10594 Answers
SOURCE: I have lost instructions
Please download required Instruction Manual from HERE.
Posted on Feb 03, 2009
How do you unlock lost pin number on satellite box Hdsr300
Maybe you can find the needed info in the manual?
Labgear HDSR300 Manuals
Also have here some additional information on this Sattelite Receiver which might be useful:
HDSR300 Rubish
Items found similar to Labgear HDSR300 HD Satellite Receiver Remote HDMI...
Labgear HDSR300 setup
Aug 03, 2015 | Cell Phones
In my philips SAA1732 fm is not working, if put scan, it scanning my no channel were is found. i connect to outside aerial but it still not detecting any fm stations... what i should do sir, please suggest...
You probably need to install a proper fm aerial and diplexer, is your aerial a TV aerial or a radio aerial?
You need to set it for the correct TV system in the software to get the audio from the TV, there will be a number of options like PAL I or PAL M or N. etc They have different sound settings, you need to choose the correct one for your system.
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Why, when listening to DAB radio in the car (professionally fitted) is some of the speech occassionally repeated ?
Thanks for writing to Fixya.com.
Although the DAB signals are less prone to interference, they're currently weaker than FM signals, which can cause problems if you're in a fringe reception area .Please check into this. Moreover DAB radio stations are "compressed", so that lots of stations can be squeezed into the available bandwidth. Because of this compression, some stations on DAB are not in as good a quality and you are getting repetition issues. Thanks for contacting Fixya and please accept the solution if it has helped you.
Mar 31, 2010 | Car Audio & Video
My laptop is Toshiba M300 and I use FM Tuner Utility under NXP FM Tuner in all programs.
Mar 14, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
Adding tv to a dish network dvr
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Dec 24, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Combining output from dish home distribution with ota antenna
Sep 18, 2008 | DISH Network Televison & Video
maybe you can find the instructions online, or try google it,if not talk to the store or company you bought it from
Aug 17, 2008 | Computers & Internet
Dish Network DVR
You have what is called a diplexer in the back of the the receiver in the front room.It looks like a splitter.If it is put back on in the wrong way you will have a fuzzy screen.look at the diplexer,you will see in/out which would be the input on a regular splitter,then you will have one side that would be one of the 2 outputs that will say SAT,the other side is UHF/VHF.The chances are that when you plugged them back in you had them swapped.Try changing the 2 cables around.If that doesnt work try changing the assigned channel to 68.You can also try doing a auto channel search on the tv in the room without the receiver.this will find the channel that the front room receiver is broadcasting the signal on.Chances are though that your diplexer wires are configured incorrectly.remember,the in/out should plug into the back of the receiver (satellite in)and the UHF/VHF should be going to the other room with the problem and the SAT side of the diplexer should be wired to the satellite dish.GOOD LUCK! rate me with the outcome please.
May 09, 2007 | RCA DISH Network(r) 311 Satellite System
239 people viewed this question
 Grubhead
Grubhead
