Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
POWER ON/ OF
AL PRENDERLO MUESTRA LA IMAGEN, Y EL AUDIO SE ESCUCHA LO HACE POR 40 SEGUNDOS LUEGO SE APAGA, EL LED DE LA LAMPARA Y LA TEMPERATURA SE QUEDAN ENCENDIDOS.
EL FAN DE LA LAMPARA CUANDO QUIERE TRABAJA Y CUANDO NO NO TRABAJA LOS VOLTAGES QUE ALIMENTAN EL FAN ESTAN BIEN LA MAGNAVOX NO VENDE SEPARADO EL FAN HE TRATADO DE ADAPTAR VARIOS CON CARACTERISTICAS SIMILARES PERO EL EFECTO ES EL MISMO
  • yezzidv Nov 08, 2008
    WHEN I TURN ON SHOWME PICTURE, AND THE AUDIO ONE IS LISTENED BY 40 SECONDS SOON GOES OUT, THE LED OF THE LAMP AND THE TEMPERATURE REMAINS IGNITIONS. THE FAN OF THE LAMP WHEN IT WANTS WORKS AND WHEN IT DOES NOT WORK THE VOLTAGES THAT FEED FAN IS GOOD THE MAGNAVOX DO NOT SELL SEPARATED THE FAN I HAVE TRIED TO ADAPT SEVERAL WITH SIMILAR TYPICAL BUT THE EFFECT IS THE SAME
  • 599 Answers
Are you supplying the TV with the proper voltage? could your source be less /more than the unit requires?...is there a reset inside for power surge/overload senarios?...... you need to find wiring diagrams and test for failed components.... ?.... good luck
Posted on Nov 08, 2008
  • 83 Answers
Plz. describe in english
Posted on Nov 07, 2008
Sanyo 32 inch blinks off
How many times do this standby light blinks at one time switch ON. Count it. These are fault indications, called blinking codes. From these number of blinks, you can get an idea about the faulty circuit section inside the TV. If you wish to get more details about these blinking codes, http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option. Blinking codes detail to many brand TVs are given in detail.
Jun 24, 2013 | Televison & Video
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
EL SENSOR DE BENCINA DEL PANEL SE QUEDA PEGADO LO LLENE Y SIGUE IGUAL CUAL SERA EL PROBLEMA. EL SENSOR DE TEMPERATURA AL INICIAR ESTA AL MAXIMO LUEGO BAJA Y ANDA PARA ARRIBA Y ABAJO DONDE SE ENCUENTRA ESE...
El sensor de nivel de combustible (bencina) se encuentra al interior del tanque de combustible
El sensor de temperatura del refrigerante del motor (ECT o Engine Coolant temperature sensor) se encuentra en el paso del l?quido refrigerador de la culata. El sensor ECT es una resistencia variable cuya resistencia cambia seg?n la temperatura del refrigerante del motor. Cuando la temperatura del refrigerante es baja, la resistencia del sensor es alta, cuando la temperatura del refrigerante es alta, la resistencia del sensor es baja. El m?dulo de control del motor (ECM) controles TEC tensi?n cincuenta veces por segundo y utiliza la informaci?n para ajustar el inyector de combustible de ancho de pulso y el tiempo de encendido. Cuando la temperatura detectada es muy fr?o, el ECM enriquece la mezcla de combustible.
Espero que esto le sea de ayuda.
Feb 06, 2011 | 1992 Hyundai Sonata
Cuando enciendo mi tv no da imagen solo parpadea una luz de lamp y se apaga de nuevo lo hace tres veces y se desconecta el solo
usted nesecita una lampara nueva le recomiendo que habla a samsung , ya que biene toda la lampara comple i con isntrucciones como reemplazar la lampara
Sep 03, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
No picture after changing bulb
Al encender el televisor , la luz verde se enciende, parpadea, se apaga, luego sale la roja, el ventilador sigue funcionando, no da imagen ni audio.
El tecnico asegura que es la lampara que esta en la parte de atra del televisor
Mar 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
