Question about Magic Chef CAV2000 Top Load Washer
Itis a 'no spin".
Months ago, I washed a small bathroom area rug and was upset because it shed much. Later on, the problem began with slightly wet clothes after the spin. Now, for a month it washes, it drains, then it rinses, bypass the spin function to the Off dial. Is the drain pipe clog? If so, how do I unclog the drain hose?
  • 641 Answers
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Sep 04, 2007
SOURCE:
Model 110.28922791. Why doesn't it drain and spin after wash cycle complete?
It went out of balance spin you dial to where spin cycle starts not fill an spin just spin and push in to start the spin again
Hope this helps Mike
Jan 30, 2016 | Kenmore Washing Machines
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
I have a new washer. Less than 2 months old. I always use the regular cycle but today I needed to wash a very small rug. I used the quick wash and iti took forever. Then at the end( after the cyle) the rug...
I just need help. I do not want to pay anything to have this question answered. I paid $1,200 for these two new appliances less than 45 days ago! I thought this site was connected with GE. Apparently not.
May 26, 2008 | GE Washing Machines
WILL NOT SPIN ON HIGH
The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground
Nov 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin or agitate
you need to remove the cabinet to expose the washer. once you do that you need to remove the 2 clips that hold the pump to the motor. then remove the 2 1/4 inch screws that hold the 2 clips onto the motor. ( remove the wireing connector first) remove the motor and Im sure you will find that the coupling need to be replaced. There are 3 parts to the coupling. 1 rubber and 2 white plastic parts. replace the coupling and install everything in reverst. your washer should work fine after this.
Jul 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Magic Chef CAV2000 Top Load Washer Logo
141 people viewed this question
Top Magic Chef Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
