Question about Ricoh Aficio 450 Copier
Paper fold when paper pass by folds like accordion before it comes out
    Problem Solver:
  • 19 Answers
You need to change the registration clutch. And never use any sprays or liquids to clean them up. It doesn´t matter what size of paper you use.
If you´re a Technitian you will now how to clean them up. If not just replace it
Posted on Dec 24, 2008
  • Ricoh Expert
  • 1,326 Answers
What size paper are you using LTR or LRT-R? You may need the regisration clucth & the pre-regisation clutch to solve the problem, it is a timing problem with the two clutchs. If you are using LTR size paper and it shows up try runing the paper the LTR-R direction, the copier runs slower with that size paper and it may off set the timing. You may also have to clean or replace the transfer lift unit, only if you get a error code. Good Luck
Posted on Nov 08, 2008
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
Jamming from all trays, all paper types. Accordion-type paper jamming taking place right behind bypass tray (section C on printer diagram).
The accordion folds indicate all the types of paper are striking something beyond the feed point. There is probably a scrap of paper stuck in the machine, no doubt out of sight and hard to find. If you are able to locate and remove the obstruction, operation should be back to normal
Dec 20, 2012 | Ricoh MPC4000
HP color laserjet 4600 folds paper
Clean the inside and check for any gunk built up try unplugging it for atleast 2 hours if neither helps then probably will need to be changed also try doing a calibration on it before buying item
Apr 26, 2017 | HP LaserJet 4600dn Color Printer
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
How can I print booklets?
One sheet booklets generally are two-sided printing jobs, accordion fold, gate fold or quarter or half fold styles. Determine which of these styles your's will be and make a "dummy"'s as simple as folding the paper according to its finished form and marking each of the panels with scaled type or pictures. By making the dummy, the layout will reveal itself when opened and flattened. You will most likely have to "flip" the pages and print each side at separate times unless your machine is a "duplex" type of printer. The "dummy" is the key to the puzzle. Simple as folding and unfolding the panels.
Jan 30, 2011 | Canon LASER SHOT LBP-2900 Printer
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Paper is coming out folded - accordion-like
Sounds like the fuser is worn out/damaged or maybe your paper is damp.
Feb 24, 2008 | Minolta magicolor 2200 DeskLaser Printer
Ricoh Aficio 450 Copier Logo
158 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
