Question about Magic Chef CAV2000 Top Load Washer
Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
Months ago, I washed a small bathroom area rug and was upset because it shed much. Later on, the problem began with slightly wet clothes after the spin. Now, for a month it washes, it drains, then it rinses, bypass the spin function to the Off dial. Is the drain pipe clog? If so, how do I unclog the drain hose?
  • 641 Answers
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Sep 04, 2007
SOURCE:
New high efficiency. Washed a bath rug on wrong setting & rug so soaked, cannot even lift it! How do get to run on "Drain & Spin" cycle?
You should just be able to turn on the power and push the "Rinse Drain and spin" button to do an extra Drain and spin OR you should be able to select just the "drain and spin" option with the knob depending on your control panel type.
I hope this helps.
Feb 09, 2016 | Kenmore Washing Machines
On a Maytag Maxima XL front load washer, please tell me on what cycle to wash a bathroom rug. zo vs
the heaviest cycle there is . but it sounds like the control board is not advancing the timer if it sits that long on one thing perhaps a call to a repairman is called for .
Jun 22, 2015 | Maytag Neptune MAH5500B Front Load Washer
THE WASHING MACHINE WASHES THE CLOTHES BUT WHEN IT COMES TO "SPIN"THE MACHINE STOPS. SPIN ICON KEEPS ON BLINKING.
Check your drain pump. It is on the front lower side of the machine. There is a small door which opens to it. Unscrew the filter and the pump cover. Be careful when you do this. There is a small drain hose next to it. Use this hose to drain to a pan before opening the filter lid.
Aug 16, 2014 | LG Washing Machines
Error code f 50 stop and keep beeping
washed to small bathroom rugs.. on bulky items. low suds stopped at F code and can not get to rinse and drain and whole dial lit up. Tried removing one rug of 2 to lighten the load. still not working. Tried unplugging it and waiting. have had about 2 years. HELP.. read the directions.. it appears using bulky items was not wise. over did the agitation.. made too much suds?
Jul 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
WILL NOT SPIN ON HIGH
The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground
Nov 01, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Itis a 'no spin".
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Magic Chef CAV2000 Top Load Washer Logo
190 people viewed this question
Top Magic Chef Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
