Question about Maytag Dryers
Maytag dg303 gas dryer
My gas dryer lite up runs for about 10 seconds tnen the fire goes out just change the hi limit thermostat did not help
Change the flame sensor
Posted on Dec 11, 2009
    Sergeant:
    Champion:
  • 324 Answers
Change the 2 coils on the valve.
Posted on Nov 07, 2008
My maytag dryer #MDG4806AWW starts but only runs for 10-15 seconds?Then turns off.
Heater limit thermostat should be change by an electrical specialist
Dec 11, 2014 | Maytag Dryers
My maytag model- MGD5740TQ0 gas dryer burner fires only for 10 seconds and stops; repeats every 2 minutes or so buy does not stay on long enough to dry load
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 22, 2010 | Maytag Dryers
My Maytag dryer lites then goes back out after a few seconds. It will lite again then goes out again. Model MDG7600AWW
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 21, 2010 | Maytag MDG7600AW Gas Dryer
Gas Dryer only runs burner once after starting, why
Lets see, you have power to the gas assembly so the fuse is good and the ignitor will fire up. But she won't fire off again. The flame sensor is working because the ignitor is coming on and off. That means the control thermostat is working so everything is working. So what's the problem. Simple.933a1bb.jpg The solenoid coils heat up and quit on these machines with a little age. Very difficult to diagnose unless you know the trick.
Cheap parts link, your part sir: AP3094251,
May 14, 2010 | Maytag MDG2706A Gas Dryer
Dryer spins, ignitor lights gas, then after 30 seconds gas valve shuts and fire goes out.
This may be a normal issue. Or you could have a vent restriction cutting off your hi limit thermostat early. Let the dryer run for 30 mins and look through the peep hole if your ignitor fires up and your gas valve doesnt open then your valve coils could be failing. Check to see if you have good airflow outside. If you do then replace the gas coils part number is 5303931775 they are located on top of the gas valve and have white connectors going to them one is a three prong and one will be a 2 prong. you dont have to shut the gas off to replace them.
Let me know if this helps
Jan 22, 2010 | Maytag Dryers
Maytag gas dryer ldg7314aae my flame will not stay lit. Heats up flame kicks on then goes for about 20 seconds then shuts off. The dryer runs for about 20 more seconds and then the same thing happens...
you have done a lot . try running the dryer off the vent . when the burner is short cycling it a air flow problem . if off the vent does not solve problem ck the fan for a bad center . very common problem . and clean vent . ck outside for air flow and condition of vent hood .. hop this helps ..
Dec 03, 2009 | Dryers
Gas neptune dryer fires up for 45 sec. to 1 min, then goes out
Could be a couple different things,Possibly a thermostat or high limit that is kicking out too soon,also has a flame sensor next to the burner that can come and go.if you have a toggle switch or pushbutton switch you can unplug the unit take the two wires off the flame sensor (black box about the size of a cigarette pack on the left of the burner)plug them into the switch start the dryer Turn the switch on till the igniter glows bright,turn the switch off and the burner will light if it stays lit at least till it gets to temp replace the flame sensor.(It won't cycle with out flipping the switch each time)
Sep 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer runs and tumbles but will not heat up to dry clothes. model # LDG7500AAW, serial # A3351803. it does have flame but will not stay hot. Is this a thermostat problem?
I would suspect a faulty high limit thermostat is causing this problem. It is usually a small round, black device mounted on a small plate and attached to the internal ductwork with two screws. Hope this helped and best wishes.
Aug 05, 2009 | Dryers
Maytag Neptune gas dryer MDG4000AWW not heating properly.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Jul 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
302 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
