Question about Compaq Presario Notebook
Compaq presario r3000 laptop power cord jack
Do you have a procedure for fixing this?
  • 2 more comments
  • scotte6 Nov 10, 2008
    Yes I can disassemble. I have had it apart but did not get all the way down to the circuit board. I cautiously backed out until I could get some feedback from someone that has done this. I'm thinking that the jack needs to be resoldered on to the board, is that what you have seen? Do you have any schematics or disassembly instructions?
  • scotte6 Nov 24, 2008
    I took windbreakers advice and bought a new jack from ebay. Soldered it in yesterday and pc works great!
    Thanks for your help!
  • springerjm20 Jan 14, 2009
    Hi Guy's,
    I am having the same problem with my presario r3000 and I have found that my power cord is fine by using a simple tester to test the continuity so this leaves the jack, just like it was with a lot of other people.
    That being said, how do I remove this jack to replace it, I have tried taking this thing apart from the back but I run into road blocks, Need help.
  • Asish Sharma
    Asish Sharma May 11, 2010
    can you disassemble your notebook and assemble it...if not than i suggest you get it fixed at a repair centre.
  • 38 Answers
If you are good with a soldering iron, you can replace the Power Jack. For a replacement part, Google COMPAQ R3000 POWER JACK. You will find the part on eBay for about $6.
If you are not a soldering whiz, take either the complete machine or the system board to a repair shop. If you provide the part and the board to a shop, replacement cost should be failrly low.
After the Power Jack is replaced, reinforce it with a bit of 5-minute epoxy to prevent flexing.
Remember - Power Jacks usually break because of rough handling. Plug the cord straight in and pull it straight out, no twisting, no bending.
Good luck
Posted on Nov 17, 2008
  • 541 Answers
I would go for the repair centre.
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like
Dec 29, 2012 | ASUS K52n-a1 Notebook
Intermittant power when using the power cord.
yup probably the power cord. try replacing a new one if you have or try borrow from your friend just to test if the problem is really in the power cord
Dec 07, 2009 | Compaq Presario R3000 Notebook
My r3000 has a tempermental power supply. it
whatabout the lead that plugs into the laptop ? does the plug in the laptop move easily, with the lead in, Sounds like the actual plug in the laptop is breaking away, the solder around the connector. Sadly to fix that you will have to get it repaired for about £50 to £70, maybe more ?? please make sure the lead from power supply is not loose or a bad fitting.
Jun 14, 2009 | Compaq Presario R3000 Notebook
R3000 DC025052300 unplugged
Right after the rj11 jack where you plug your landline in. You can follow the leads easy from the jack. Opposite side of the processor side.
Jan 30, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Sound card problem - I tap on PC to fix
it can be replaced you just have to have the patience to do it
Dec 28, 2008 | Compaq Audio card Sound Card
My Compaq R3000 does not charge up
The problem might be the battery itself. Four years is a long time for rechargeables. Also, check if the error ocurs when the battery is not in the slot.
Oct 27, 2008 | Compaq Presario R3000 Notebook
Compaq Persario R3000
i have a problem can you please send me a atachment of this driver base system device so i can instal it to my laptop compaq presario r3000
my email is
Sep 04, 2008 | Compaq Presario R3000 Notebook
All kinds
It's the power connector on the motherboard, and the more you wiggle the connector on the cord to make contact, the more you damage the motherboard (from the sparks and heat).
There are a number of sites on the web that offer to fix that problem (it's probably the worst part of the design of any laptop) for prices ranging from around $75 to $200 - try this search to find someone you feel is competent:
Aug 19, 2008 | Compaq Presario R3000 Notebook
Compaq Presario Notebook Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
