Question about Dryers
KENMORE SERIES 70 DRYER SQUEELS AND THEN QUITS
When I first push the start button it hums and then after a few seconds the dryer start but does no run very long and after a few minutes it squeels until it quits and then sometimes I push the button and it starts again but now most of the time I push the button and nothing happens I then have to wait awhile
  • carriediede Nov 07, 2008
    how do you do that
    Top Expert:
  • Dryers Master
  • 79,077 Answers
There may be a problem with either the dryer start switch or the motor itself, start by replacing the start switch.
Posted on Nov 07, 2008
  • yadayada
    yadayada Nov 07, 2008
    There is another item, you said it squeals when started, the dryer drum rear bearing may be defective. Pull the front off the dryer and check if drum turns freely.
    Sergeant:
    Novelist:
  • 196 Answers
Check out the motor is it proper.
  • mmechanics Nov 07, 2008
    also try cleaning the motor area.
    if somedust is blocking the motor to spin this could happen.remove all the connections clean that motor area and the plug in all the connections and check it.
Kenmore 70 series electic dryer wont start make humming noise
your motor likely has a start-up capacitor to start the motor, it will be a cylindrical unit with 2 wires going to it, bring this with you to your local appliance repair depot and ask for a replacement with the same numbers on it, re-install as the old unit was uninstalled, this will likely the problem
Apr 15, 2012 | Kenmore Dryers
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
DRYER WON'T START WHEN START BUTTON IS PUSHED
if its a humming than a click,,wont start for a few mintues,,than the hum again ,,your motor is shot,,,replace,,onthejob
Jan 05, 2009 | Kenmore 62872 Electric Dryer
Kenmore 70 series dryer cuts off after 10 minutes
You first shoul check the belt to see if it is not broke or twisted. If not then your motor is heating up and thios causes it to stop. a new motor would be your problem.
Dec 02, 2008 | Kenmore 63942 Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Kenmore gas dryer. 70 series
sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
Apr 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Dryers Experts
