Question about Canon PIXMA MP510 All-In-One InkJet Printer
CANON PIXMA MP510 WILL NOT POWER ON
My printer has been powered off for several weeks because the black ink cartridge needs replaced. I'm trying to turn it on to replace cartridge and it will not power on. I've tried other outlets and still cannot get it to turn on.
  • MirOz Jan 29, 2009
    I have not used my pixma for several weeks and have the same problem.
    This is the second pixma with this problem, we exchanged the first one.
I had a similar problem. What worked for me was to remove the power pack, which is secured by two clips. Slide a knife or similar to release the power pack. It will slide out to reveal a mini-plug with five red wires. Disconnect this.
This where it gets a bit uncertain. I plugged in the power pack and put a meter across the outputs. They seemed to be working (ie I was getting voltage). I had a quick look at the indide of the MP510 and decided there was nothing further I could do. I then reassembled everything and, just out of curiosity, pressed the power button again. And it came back to life!
I suspect that in your and my cases, the MP510 had "crashed" and I performed a hard reset by removing and then reconnecting the power pack. But who knows? Best of luck
Posted on Jan 27, 2009
Hurri Up's solution totally works!
No need for knifes though. Unscrew the one plug and just click it open. Very relieved!
Posted on Jan 29, 2009
  • arnold mauer Dec 13, 2010
    I have the same problem, the power get off after replace the cardridge, I deside to do the same like you did but it does not work!!!
    even I change the power pack with my other mp510 it still doesn't work.
    Bad luck for me?
    Artino
2 Suggested Answers
komguy
  • 2306 Answers
SOURCE: Will my Canon MP510 work if Black ink cartridge installed alone?
No, Canon machines only work with all inks installed, you can get air bubbles in the printhead without inks and that would ruin the printhead.
Posted on Jan 14, 2010
Mp510 waste ink needs emptying
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jan 22, 2013 | Canon PIXMA MP510 All-In-One InkJet...
Need to print only black ink on canon mp510
in the printer set up ( normally in the print section , change the color to black and white , make default and ok
Jan 11, 2012 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
My printer won't print black
Did it print black before you replaced the black cart?
If so try 1. purging the new ink cart. 2. reseat and purge 3. rpl it is defective.
Feb 21, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Where are the ink cartridges located in my MP510 Canon printer?
open the panel on the top with the power on and they should come from the left hand side and stop in the middle needs to be plugged in and on
Dec 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
No black ink printing
Try reinstalling the printer, as it sounds like a driver problem. This shouldn't happen, but occasionally the drivers get corrupted. And refilled cartridges certainly don't help, and may continue to give trouble even when replaced with OEM ones. Have you tried turning the printer completely off - disconnecting the power lead, for a few minutes? That sometimes clears things.
Jun 27, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Frequent problems with the magenta cartridge of my PIXMA MP510.
Dirty or faulty contacts in the cartridge chamber is the only logical explanation.
Remove the cart and with a cotton wool bud and a little alcohol or similar[NOT ACTETONE it melts plastic] give a gentle clean.
Oct 24, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
1,954 people viewed this question
old marine
old marine
