Question about Maytag Neptune MAH5500B Front Load Washer
Black mold on rubber seal
My Maytag Neptune washing machine has developed black mold on the rubber seal for the door. I have tried cleaning it off and nothing works. What is the answer to this problem?
  • karenlmore Nov 12, 2008
    I do not understand this answer. I understand that I may have to replace the seal, but what is the recommendation about maintaining it? What is the "boot" and what is Affresh? How do I "whipe out" water and from where?
    Karen More
  • 62 Answers
Youust replace it, and start from scratch. From day one you have to maintain the boot with Affresh, whipe out water
Posted on Nov 09, 2008
  • cmcarter13 Nov 13, 2008
    the rubber piece around the front of the drum and attached to the front of machine is the door boot. The Affresh is tablets you can get at Lowes, Home Depot,Sears. You use once a month. You wipe out water from the bottom of door boot, you can pull back on it and find four holes that drain back into tub, I hope this helps.
My maytag neptune washer has black residue on the seal. I have tried everything & nothing seems to take it off. I am now concerned that it is mold. Has anyone experienced this same problem?
Hi just read your posting.The black residue is most likely mould.I have seen it on a few front loaders.Have you tried the product called Mould off ?It helps on some machines.Worse case you might have to replace the door seal.Please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Maytag Neptune MAH6500A Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Mold on rubber seal on Maytag front load washer
    this was and is still a common problem with maytag and for the most part all front load washers... make sure if your rubber seal has a hole in the ceter for the drain it is clear and not clooged partially... the only solution really is clean it with a cleaning solution to kill mold and then after each cycle try to leave door cracked so that air gets to boot/seal so that it stays dry....
    hope this helps.... maytag actually had a lawsuit over the neptunes and now are owned by whirlpool coorporation due to that law suit and a dishwasher they had that would catch fore... servicer for 18 years now good luck to you
    Jan 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
    Neptune washer front door seal has black build up
    Try pouring a cup full of distilled white vinegar into the soap dispenser drawer while it is filling up on a hot wash. Don't put any washing in, just let the machine go through the full cycle. Repeat if necessary.
    You may be able to scrub lightly affected areas of the door seal with a scourer or old toothbrush etc. and something like Jiff. To be on the safe side you should wear goggles and a mask when dealing with black mold.
    It may be worth trying a black mold remover available from supermarkets but read the instructions to make sure it is safe to use on rubber if intending to use it on the door seal. If badly affected - the only way to get rid of it - is to replace the door seal.
    Nov 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
    RUBBER LINER COLLECTING MOLD
    I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
    Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
    My front-loading Frigidaire washer has black mold on the rubber seal. How can I get rid of the mold? And can it be prevented?
    Clean with bleach solution and a Mr Clean Magic eraser.
    leave the door open to dry out the machine from now on.
    Nov 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    Black mold on washer door seal
    this is a very common problem with the neptune washers.
    use a javex and hot water solution and scrub the rubber boot.
    you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
    There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
    this will allow for air movement in the washer
    May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    Maytag front loader washing machine. Mould
    How old is the washer? Did you try straight bleach on a towel and placed over the "mold" spot for about 5 minutes, be sure to wear gloves. Then scrub with a small brush being careful not to splatter bleach on yourself and rinse well. May need to replace the seal. I always leave the door cracked open after every use to "dry" out the inside and the boot. I also leave the drawer pulled out when not in use for that area to dry out as well. I have never had mold on the door seal of my Neptune washers, only the water holes above the dispenser drawer.
    Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
    Maytag Neptune MAH5500B Front Load Washer Logo
    1,540 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
