Question about Palm Treo 700p Smartphone
Camera My treo 700p camera or camcorder will not work.I get this message. Unable to launch camera because no camera is present in the device. What can I do Please help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 848 Answers
Camera? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 190DTLA A2H PI 190DTLA PI 170DTLA 200 000 170DTLAH V7 860 AB0...
Posted on Jan 12, 2015
    Sergeant:
    Champion:
  • 258 Answers
Send it back unless you want to take the phone apart and try reseating it.this can only be done if you have a T5 screwdriver, available at sears or online.
there are youtube videos that show you how.
The camera may be bad, you can buy another on ebay
or you might try a hard reset.
Ken
Posted on Dec 07, 2008
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Bluetooth connetion with Verizon Treo 700P
Looks like your saying you've updated your n?vi 660 to software(firmware) version 2.0, if so you're moving in the right direction. Unfortunately the n?vi 660 does support the Treo 700P but only seems to support the 'Hands-free' BlueTooth profile and this is often problematical as is the 'headset' profile with some device combinations, that's precisely why many phones and devices now support both profiles. Check the pairing information to see if you're using 'headset' or 'Hands-free', whatever you're using delete the pairing on both devices and see if they will let you pair in the other profile. Your Treo 700P is made by PalmOne (www.palm.com) so you may want to check for software updates from them. This kind of problem is down to the lack of a solid standard for BlueTooth communications and you will often find that settings that work for one combination of devices are unstable with another. Post back if this doesn't help or if you need us to clarify anything.
Aug 18, 2007 | Garmin Nuvi 660 GPS Receiver
I replaced the screen in my palm treo 700p and now the phone works but the screen wont come on.... what do i do?
Can you hear it ring when u try to call ur number using a different phone? If yes, maybe it isn't aligned properly or check the connector.
If no, the software is crashed, it needs a software reflash/reprogram
Dec 15, 2009 | Palm Treo 700p Smartphone
Treo 700p locks on Access Powered
I called Sprint tech support. With the battery in, hold the red power button down until the screen comes on that asks you if you're sure you want to reset your Treo (you will lose all information but hopefully you're like me and synch it frequently with your desktop.) I reset it and then synched it with my desktop and got almost all my info back - just had to redo email passwords and some settings. It was easy.
Sep 29, 2008 | Palm Treo 700p Smartphone
Treo 700P Charging issues
I'm assuming you have problems with syncying also. What I do is turn off the Treo, take out the battery, and unplug the the cord from the USB port. With everything unconnected clean the contacts in the treo, on the outside of the treo and the plug on the chord with alcohol on a Q tip. On the battery only clean with a dry cloth, no alcohol.
Put it all back together and see if you get a better connection. If this doesn't work it is probably your battery.
Jun 11, 2008 | Palm Treo 700p Smartphone
700p bluetooth set up with Sanyo GPS 4050
I got the pairing code via searching the internet it is 0000 and worked just fine. Now however I get an "Unable to connect message". Sanyo tech support is very hard to get a hold of.,.
May 12, 2008 | Sanyo NVM-4050 GPS Receiver
Received remanufactured 700p, can only use speaker phone
Can you confirm the earpiece is compatible with your 700p treo?
Dec 11, 2007 | Palm Treo 700p Smartphone
Nonworking keys on Treo 700p
make sure first of all that there arent any screws missing or loose in the back by removing the battery cover....thats can cause the keypad buttons to not have a good connection to circuit board... if thats ok then you can use a toothbrush and some alcohol (denatured alcohol if possible) to rub and clean the keypad. If all that fails, I know that Sprint offers repair for their phones.
Nov 11, 2007 | Palm Treo 700p Smartphone
Palm Treo 700p Smartphone Logo
195 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
