Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile 30" Built-In Downdraft Modular Gas Cooktop JGP389BEVBB knobs wont turn
Two of the burner knobs will no longer turn. I know of someone else with the same model and the same issue. Any ideas?
  • furg Nov 12, 2008
    I found some adjustment screws in the center of the knob posts, but they don't appear to help my situation.
  • furg Nov 13, 2008
    Estimate from GE 2 x WB24X5345 at $66.70 plus labor-- quote totals $320.06.
5 Suggested Answers
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
  • 71 Answers
SOURCE: I have a GE profile
unplug the cook top under the counter, let the switches dry out about a a day then try again.
Posted on Dec 27, 2008
mrfixit3667
  • 262 Answers
SOURCE: ge profile gas range. one burner with no clicking and no ignition
Try one to light one of the other burners that work and watch the electrode on the burner that does not light and see if you have spark when you here the clicking nois. (( most gas cooktop spark ignitor all spark at the same time, even if your only trying to light one burner ))
If you do have spark, Then the Ignitor switch is bad.
If you don't have spark then your spark modual is bad.
Posted on Jan 10, 2010
How do i fix a squeaky control knob on a ge downdraft cooktop?
silicone spray works wonders !!!! and most silicone's are food safe too (look 4 it on label) so its safe to use around food prep area's, it however does not taste 2 good to the human palate so use sparely
Jan 05, 2016 | General Electric PP989TNWW GE Profile 30"...
GE Profile Gas cooktop burners blow out
This sounds as though the pressure is too high.
Feb 11, 2015 | General Electric PGP953DETBB GE Profile...
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Exhaust turns on automatically in burner mode
Hello
I have the one with the 4 burners and the grill, and when the grill in on the fan has to come on, and it does automaticly, but once you finish with the grill you have to change it back to stove mode by putting the 2 burners back or the fan will allways go on when you turn the switch. It is a safety regulation for the fan to be on with the grill to avoid the fumes......I know I hate that too.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 19, 2008 | GE 30 in. Profile JGP979 Gas Cooktop
Order in black w/matte finish grates & downdraft cover
No. If it is really important order the grates and downdraft cover as replacement parts. This will be expensive probably around $200 - $300.
May 25, 2008 | GE 30 in. Profile JGP989 Gas Cooktop
Ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Oct 26, 2007 | GE Profile JGP636 Gas Cooktop
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
183 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
