Question about Fujitsu Siemens Lifebook N5010 Notebook
Automatically Shutting Down then unable to turn back on
November 7, 2008~
My lifebook shuts off automatically. When I attempt to turn it back on, I can hear the fan running and the lights illuminate across the top indicating that there is power but the screen remains black. I have to push the on/off switched at least thirty times before the screen finally displays. In most instances, it just continues to power off. I have used te liquid dust to clean the fan and I also have a laptop fan I use all the time to attempt from overheating. Not knowing much about computers, someone suggested that I may require additional memory. This worked for approximately two months and here I/we are again with the same issue.
In the instances when the lifebook powers on I cannot connect to the internet (which has not been a problem until the automatic shut off).
Also, I have an external wireless device (D-Link). Now I am receiving an error message stating that I need to place the usb in an 2.0 outlet. I am using a 2.0 outlet but the device is not recognized.
If there is no solution(s), I will have to restore the lifebook to original. Unfortunately, I cannot afford a new laptop and obviously I do not want to loose all info/data but if there is no solution(s), I will have no choice but to restore the lifebook to it's original state. I am SSOOOO frustrated !!!
PLEASE advise ASAP !!!
Thanks,
Rhoni B. (Chochynadl@aol.com)
    Novelist:
  • 116 Answers
Sounds like overheating, if the machine just cuts off its either power fault or overheat and the machine will hit a certain temp about 90C for a period and cut out to prevent severe component damage .
you can try cleaning again, the thing is if its been running at high degrees C it may need fresh arctic silver on the CPU which thankfully is a pretty robust one in that machine.
hope this helps, let me know if you need further help
Posted on Jun 11, 2009
I shut down my toshiba copier 282 in the right way . It gives me the message shutting down in progress but it doesn't shut down automatically as before. It only shuts down with the on/off switch
AD+206
Auto Shut Off Mode timer
setting (Auto Shut Off
Mode/Sleep Mode)
ALL Refer to
content
<0-20>
SYS Timer to turn OFF the
power or to enter the
Sleep Mode automatically
when the equipment
has not been
used
0: 3min. 1: 5min.
2: 10min. 3: 15min.
4: 20min. 5: 25min.
6: 30min. 7: 40min.
8: 50min. 9: 60min.
10: 70min.
11: 80min.
12: 90min.
13: 100min.
14: 110min.
15: 120min.
16: 150min.
17: 180min.
18: 210min.
19: 240min.
20: Not used
check this or update firmwear
Sep 29, 2016 | Toshiba Office Equipment & Supplies
My ps4 is shutting down automatically after playing for 5/10 minutes. What to do?
it looks like it is heating up. heat fan replacement can solve the problem.
Mar 01, 2015 | Computers & Internet
My Ipad Mini keeps shutting off automatically, then turns back on. When the home screen is shown it just keeps glitching and shutting off. Whats wrong with it?
I would first try doing a hard reset. Hold the home and power button down simultaneously until the iPad completely turns off and the Apple logo appears. You can ignore the slide to turn off button when it appears.
If that doesn't solve the issue I would make an appointment with your local Apple Store and have the device checked out by an Apple Genius.
Hope that helps!
Mar 22, 2013 | Apple iPad Mini
Sony Vaio netbook will not connect to internet - says limited connection
That's usually your router, not the computer. Sounds like your computer is connected to your router, but IT is not connected to the internet.
I would suggest shutting down the computer, shutting down router, then the modem, plug the modem back in, waiit for lights to finish blinking (should be within a few minutes) then your router, once that's finished blinking, then turn on your computer.
Jan 15, 2011 | Sony VAIO VGN-NR160ET Notebook
Laptop shuts down automatically and emits a beeping sound
Yes this is for the memory problem...Try to change the RAM...
Oct 20, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Automatically shutting off after about 5 min
dose it have a thermostat if it dose that will turn it off
Jun 24, 2009 | Comfort-Aire PAD-91 Air Conditioner
Turns on and off automatically
getting hot and shutting down try to clean it out could be very dusty inside
Jun 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Toshiba A135-S4527 will not automatically shut down
If you truly believe the problem happened right after installing the new mouse, then you should start by uninstalling the software for it. Go to Control Panel -> Software -> Uninstall. If this fails, you can use the System Restore utility to rollback the Windows registry to a time before you first installed the new mouse software. Have you tried to unplug the mouse and not use it, atleast on the attempted shutdown process?
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Fmv 7000na5
automatically shutting down is an indication of thermal issue or over heating. how ever when you say automatically shutsdown does the computer turns off? try checking your heatsink fan and the heat sink as well as the air vents. make sure all the air vents are free from obstruction and the heatsink is clear of all dust which can prevent the air from cooling your processor. if still it continues change heatsink fan and heatsink. make sure to apply the thermal grease between heatsink and processor
Jun 26, 2008 | Computers & Internet
Fujitsu Siemens Lifebook N5010 Notebook Logo
418 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
