Question about Apple iPod MA446LL/A MP3 Player
Blacked out Hi guys see I have a 30gig Ipod and the thing is that it used to freeze once in a while so I reset it but after I did that twce the screen went black and ever since i cant get it to work it responds to the resets but won't work any hint on what to do with this problem thanx.
  • 23 Answers
1.toggle you hold switch on and off 2. press and hold down the menu and center buttons in the center at the same time and keep holding it without letting go until that cute little apple logo appears usually takes about 10 seconds unless it is really frozen 3. if you get no response doing this plug into an outlet and repeat the above steps. try using 2 hands one finger on the center and one finger on the menu if this does not work it may be one of the 30 gigs that had the problem apple had for a short time go to the genious bar they will check to see if it was one of the ones that needs to be replaced. I had one like this and they just gave me a new one on the spot.
Posted on Jul 11, 2007
    Problem Solver:
  • 18 Answers
Restore it through itunes 7
Posted on Mar 23, 2007
Will not leave apple logo
Sometimes a iPod malfunction occurs that results in the Apple logo freezing on the screen of the iPod. When this happens, toggling the Hold switch or resetting the iPod typically resolves the problem. If following the manufacturer's instructions on resetting the device fails to get a response from your iPod, however, you must troubleshoot other potential solutions. In addition, taking the time to find the cause of the problem can help you prevent a recurrence of the issue.
Battery Allowing the battery to discharge completely may unlock an iPod stuck on the Apple logo. To drain the battery, leave the iPod with the Apple logo on the screen and place it in a drawer or in another safe place. Do not attempt to use the iPod until the battery drains and the screen goes black. This may take a day or more depending on the current level of battery charge. Once the battery drains, connect the iPod to your computer or to the wall outlet using an AC adapter and charge the battery completely before turning on the device. b> Restore If the iPod remains frozen on the Apple logo after draining and recharging the battery, you may need to restore the device to original factory settings. Unfortunately, this results in the loss of all data and media files stored on the iPod. Restoring the iPod, however, does not delete the files stored in the iTunes library, so you can still get your data back onto the iPod. Follow the specific instructions for your iPod model when restoring the device. Upgrade Software Problems with the version of software installed on your iPod may cause the device to freeze. Upgrading the software may resolve the problem because the updates released by Apple often include both bug fixes and software enhancements. In addition, installing the current release of the iTunes software also may resolve the freezing problem experienced by your iPod. File Corruption Often, a corrupt file can cause your iPod to fail. If you notice that the problem recurs after playing a specific song or video, then delete that file from your iPod. If the problem occurs again after synchronizing with iTunes, delete the file from your iTunes library. Then import the original file into iTunes again or re-download the file. Typically, if a corrupted file is behind the iPod freezing, a reset temporarily restores functionality until the problematic file plays again. b> App Overload Installing apps on your iPod touch can give you more than just fun or informative software. Running too many memory-intensive apps at one time can overwhelm the device and cause your iPod touch to freeze. A single problematic app may have the same effect. Limiting the number of apps running at one time or removing troublesome apps may resolve this problem.
b>
Feb 11, 2013 | Apple iPod nano 4th Generation
IPod freezes during use
The best thing to do wuld be to first, back up all of the stuff on your ipod, and the restore it back to factory setting through itunes. After that, you can put all of your files back on the ipod and it should function normally.
Dec 30, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
Help
Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Mar 17, 2009 | Apple iPod MA446LL/A MP3 Player
NEW IPOD TOUCH FREEZES!!!
you need to restore it either with itunes or manually if manuel hold home for 5 seconds dont stop while holding it put in you usb connecter your usb  connecter must be connected to the computer
Nov 19, 2008 | Apple iPod touch
Ipod 30gig/more gigbits/ capacity expansion
Yes you can get up to 160 GB or more now.. If you want to keep the same iPod, you can have the hard drive replace with a 60 GB. You will also have to change the back and battery to accomodate the larger hard drive. There are a number of companies that will do it for you and some will even send you a postage paid box. Just do a Google search for ipod repair. Hope that helps.
Sep 16, 2008 | Apple iPod nano
Ipod 30gig
Try a reset and a restore both explained on this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Reset on the top and restore on the bottom,
Let me know if that doesn't solve the problem.
If it does don't forget to rate as fixya.
May 16, 2008 | Apple iPod MA446LL/A MP3 Player
Freezing ipod
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more asistance, let me know. Good luck.
Mar 23, 2008 | Apple iPod MP3 Player
Ipod nano won't connect to iTrip car system
Mar 19, 2008 | Apple iPod nano 3rd Generation
Ipod nano not playing songs, and dying
SOLUTION!!!
I also had the same problem with my ipod nano..
Do this and i assure you, it will work..
1. Hold the MENU button and then the middle button down(in that order) together for about 10 seconds..
2. This should re-boot your ipod..
3. Wait for your ipod to start..
4. Problem fixed. It plays..
Dec 09, 2007 | Apple iPod nano 3rd Generation
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Mohamed Ismail
Mohamed Ismail
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
