Question about SanDisk Sansa Clip MP3 Player
Sansa clip 4gb mp3
No know cpu
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Only my right earphone works on my sansa clip 4gb. i know its the player because i tried different sets of headphones. Whats the problem?
The phone socket in the player is probably faulty or it mat have a dry solder joint connection.
Either way to solder or replace the headphone socket requires dismantling the player.
Jan 21, 2011 | SanDisk Sansa Clip MP3 Player
My sansa 4gb clip is not recognised by my computer. The computer will not acknowlege the usb either... My sansa has run out of battery. What can I do????
Hai, i have sansa clip 2gb with the same problem. one ultimate answer i got is Sansa clip uses Media Transfer Protocol(MTP). Sandisk(maker of salsa clip) know about the problem which cannot be solved(the earlier sansa products are to be avoided). There is no solution with the company.
Nov 15, 2010 | SanDisk Sansa Clip MP3 Player
Sansa 4gb clip purchased will not hold charge
You should and just tell them that the battery is deffected
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
How to create different playlists in "sansa clip 4GB"
download "media monkey" it is a free program that will do all that you want and more, like windows media player but a lot easier.just google it and download
Apr 26, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
SANSA 4GB PLAYER
Have you tried updating your Windows Media Player to number 11? this has the drivers for SansaClip. Go to windows website, download WMP 11 and then plug in Sansa and uyour computer should recognise it. Good luck.
Jan 19, 2009 | SanDisk Sansa Clip MP3 Player
Charging my SanDisk Sansa Clip MP3 Player
You will definitely need to get that USB charger cable.
Dec 09, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa MP3 Player (clip 2gb)
my mp3 4gb is not working at all and it needs to be reset
May 26, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
