Question about Gateway EV 700 17" CRT Monitor
EV 700 Occasionally the monitor shudders and then the light goes dim and the colour goes all greeny blue. When I switch the monitor off and then on, it works normally again - for a while
If the colors change intermittently, I would check the CRT socket.Make sure it is seated firmly against the tube. Then check the CRT socket connections which may require re-soldering. If that doesn't help, you could have a bad CRT (internal shorts). Sometimes a CRT rejuvenator can clear these intermittent shorts.
Posted on Sep 05, 2008
My gateway monitor makes a sqreeching noises when you turn it on. after that it starts making that noise like it does when its fixing to come on then it starts smelling like its burning then we turn it off. please help
Posted on Aug 30, 2007
PT Cruiser Top not working and occational lights dimming.
Have battery load tested, and alternated tested. Check. Battery cable connections, make sure they are clean and tight.
Aug 21, 2017 | 2005 Chrysler PT Cruiser
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
When I turn the monitor on it has a red green blue screen
It would appear that the monitor is not getting a signal from the computer. You should try to power down the monitor and remove the power plug and let it cycle. Also, check the VGA cable connections to make sure they are connected properly.
If this does not cause any change, you can try to connect it to a different computer and/or connect another monitor to the computer you are using this Gateway monitor on if you can do that.
Let's start see if we can get this problem solved.
Brian
Feb 07, 2011 | Gateway EV 700 17" CRT Monitor
I have a star logic monitor and it is not working. When i insert the power cord a dim blue light blinks, but then when i insert the computer to monitor cable, the dim blue blinking light goes away and it...
  1. Please try by reseating the RAM modules.
  2. Please check the VGA output port is properly fixed.
  3. Reset the BIOS to its default.
  4. Check whether the monitor colour resolution is out of range
If yes, set it to default.
Please check whether is works with different computer
IF yes, Check the VGA port.
Feb 07, 2011 | Star Logic Monitor
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
My EV 700 screen picture is condenced has one bright clear line in middle screen and two more lines faded,space in between lines
Sounds like a CRT problem but to be sure, hook up another monitor to the computer and if you get the same exact lines then you know its a problem with the video card, if the lines go away then you know its a problem with the monitor.
Jun 09, 2009 | Gateway EV 700 17" CRT Monitor
Ev 700
you must attatch agp(accelareted graphics port) card in pci slot it is specially for 3d games and excellent video output fast motion responce but if you want to see normal ordinary display then no need of agp card
Oct 27, 2008 | Gateway EV 700 17" CRT Monitor
Lg 42" plasma labeled by sky
Could be a component inside is going bad which mean it'll die soon. (it just trying to tell you to save $ for a new TV) Or wire is lose somewhere. (My work pc, I touches the monitor cable and sometimes it switchs color like you described)
Aug 25, 2006 | LG MZ-42PZ14 42 in. Plasma Television
Gateway EV 700 17" CRT Monitor Logo
91 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
