Question about Kenmore 24982 Top Load Washer
Kenmore 80 series
We have a kenmore 80 series bought it 3 years ago and the coupling broke on it we replaced it and it started to work agian but know when it spins the water won't drain unless we put the hose down on the ground and the water won't stay in unless we put the hose in the up high and I don't like standing there all day put the hose down we it's time to spin and putting it up when its time wash. If I don't do that then it does not drain hardly at all just a little and the clothes are still soak and wet. please help. thank you, lyzz
    President:
  • 878 Answers
Lyzz, someone is going to have to check the pump for debris in it. It is not hard to get off, 2 clips and two clamps. You also want to check the drain hose from the pump right at the point where it exits the washer. I have found socks and other items stuck right at that point. You are going to have to remove the cabinet to get at the pump. Yours will have a cover under the console where you will have to disconnect some hoses. I will attach a couple of photo's to guide you...Catriver..post back.
Posted on Oct 18, 2006
  • Ron Marek
    Ron Marek Oct 18, 2006
    Second photo of how the consol flips up to get at the cabinet clips.
Kenmore 80 series
Look inside the pump. Smething might be in it. If you incorrectly installed the couplings too tight against the tranny or motor then the resulting bind will cause the problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2009 | Washing Machines
I have a Kenmore series 80 that I bought it used two years ago, it now has a bad motor, it was manufactured in '96. I replaced the motor coupling a month ago. My question is, is it worth replacing the...
hello, i'ld say buying a new motor is far cheaper then buying a new unit unless the maching is in bad condition for a new motor your looking at anywere from 50.00-175.00$ depending on the model number of your machine. good luck on making your decision, and if you decide to buy the new motor and need help finding one let me know i can help you find the motor you need.
Mar 22, 2009 | Kenmore 24442
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
Kenmore Series 80 Washer goes through all cycles but will not agitate or spin.
Hi thanks for the question The part that has broken, is called the drive coupling . located between the motor & clutch. replace that part thanks the appliance doc
Oct 01, 2008 | Washing Machines
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Kenmore 80 series
I'm having the same exact problem, you posted this issue in Oct, have you found a fix?
Oct 18, 2006 | Kenmore 24902 Top Load Washer
Kenmore 24982 Top Load Washer Logo
432 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
