Question about Sony KV-27FS13 27" TV
No picture No sound
I am having the same problem when I turn the tv on I get no picture or sound, you can hear it turn on but then I get the 4 flashing standby lights at the bottom. I have tried unplugging the power to rest it but still nothing. Please someone help me.
  • MyIngham Dec 06, 2007
    Power light flashes, no picture or sound
  • Anonymous Dec 28, 2008
    NO PIC NO SOUND FLASHER 4 TIME
    Scholar:
  • 68 Answers
I agree with techman, but I call it the start-up supply, which gives the Switch Mode Power Supply Intergrated Circuit, a supply (V+). This supply is about 10 to 30 Volts and supplies a few milliamps of current to the integrated circuit (SMPS) which starts giving out pulses. The pulses switch on and off the Line Output Transistor, or a Power Transistor which energises a transformer. The transformer provides all the voltages required to work the rest of the circuits. One if these voltages takes over from the-start up supply. The failure is usually the Power Transistor, or the Transformer (line output). Replacing the Transistor will usually bring the set to life, but it may fail again due to the fault which caused the transistor to blow. The only solution is to get a service engineer who will check the components before switching on again.
Posted on Oct 19, 2006
    President:
  • 3,130 Answers
This is an indication that the sweep power supply did not give the turn on pulse from the SMPS, thats the main power supply. If you know how to use a multimeter I will send you the instructions to troubleshoot this supply. Or you may need to trouble shoot the sweep supply as well. If you have no electronic or solid state repair experience, Please stay safe and call in a trained tech to assist you with this repair. Good Luck PS please rate this thread
Posted on Oct 18, 2006
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
The picture and sound on my 55 inch Sony disappears momentarily
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL-2200.You can find it here: http://www.discount-merchant.com/Sony-XL-2200-TV-Bare-Lamp-Bulb-p/sony_xl-2200u_a1601753a_lamp.htm?Click=48173 Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Turns on and off. Sound only no picture.
Hi, do you hear clicking or like wanting to turn on? if you do it could be your ballast which is the board that powers the lamp.Do you hear buzzing,whirling,winding or spinning noises? if you do it could be an issue with the color wheel which is in charge of creating the colors on your tv. If you don't hear any of this and tv is between 2-4 yrs it's most likely time to replace lamp.http://www.discount-merchant.com/SearchResults.asp?Search=+%09+BP9600826A part number is BP9600826A but it seems there's 2 lamp with the same model,you have to check if you have the small and square lamp with 4 corners and 2 ventilation holes or the big lamp that is completely closed.God bless you have a good one.
Oct 05, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
No picture or sound
Hi,do you hear clicking or like wanting to turn on?If you do it could be an issue with the ballast that is the board that powers the lamp.If you dont hear that and tv is between 2-4 yrs most likely its time to replace lamp.Make sure you Get the Philips brand.God bless you and your house.
Oct 01, 2009 | Toshiba 50H82 50" Rear Projection...
No picture at all,sound ok 3 tube crts off after 4secs when on
might be a crooked flyback transformer, first check for shorted transistors around the transformer and components at the horizontal output stage..
Mar 31, 2009 | Philips Televison & Video
TV has audio sound and no picture
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
Trung,
There are many possibilities and most of them have to do with the "D" board, Sony p/n# A1346948A but testing is something generally beyond the scope of those less than technically equipped. You could order the whole board and put it in but that might be more than the simple fix you wanted or you wouldn't be here. So my best advice is to take it in to a qualified shop and have them estimate and repair it.. I see 3 or 4 of these sets in my shop a month, Sony XBR, and they're still very much worth the repair..
Bill
Nov 21, 2007 | Sony KV-T29CF1 TV
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
Sony KV-27FS13 27" TV Logo
267 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
