Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
When i try to setup the security on my wireless router it dissconnects and will not let me connect again untill i disable the security settings
  • Frank
    Frank May 11, 2010
    how are you try to set the secuirty on the router??
    using wire or wireless????
    you need to use CAT-5 wire connected to the router, configure it. then use the laptop, find the wireless, put in your crypted password.
  • 132 Answers
That is correct. When setting up wireless security in the router, do a wired or direct connection to the router first.
Posted on Nov 08, 2008
Security lock is on router how do i take it off
Your wireless network must be secured.
You can find the wireless security key from the router and get it connected.
Or you can simply disable the wireless security on the network.
For this you need to open the setup page of the router and change the wireless settings.
See How to open the setup page of the router.
May 14, 2012 | Belkin F5D8236-4 Router
How do you remove a security code from a wireless router?
Disabling wireless security key on the router. Just follow these steps:
Step 1: Access the router's web-based setup page.
Note: For Linksys default ip address default password
Step 2: On the router's web-based setup page, click the Wireless tab then click the Wireless Security sub-tab.
Step 3:Click the drop-down arrow for Security Mode and select Disable and save settings.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How do i reset my wps orange light stays on no internet
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 23, 2010 | Belkin (F5D7231-4) Wireless Router
Security lock on, need to remove.
Try This
Step 1 :Connect Router - Computer ( Wired )
Step 2 :Open RSP by typing on the address bar of the internet explorer
Step 3 :On the left , Under wireless Click wifi protected setup
Step 4 :Leave the password blank and click SUBMIT
Step 5 : Disable it and click apply changes
Step 6 : On the left under wireless click security
Step 7 : Disable it and click apply
Step 8 :on the left under wireless click channel and ssid
Step 9:Change the ssid into a different name And click apply
Step 10 : Connect to this new name
Mar 29, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Wont connect to internet
Yes you hve to setup the router again, the wireless setting especially.
Turn mac control off in wireless security and let me know how you get on.
Jan 21, 2010 | Linksys Wireless-G WRT54G Router
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
MacBook not connecting to DIR-655 Router
My solution was that I changed the wireless mode from "B,G and N" to just "B and G," and then it worked fine.
Nov 23, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Another problem... wireless router Allied Telesyn wa1104g
can you connect without the security???
if so. configure the router with minimum security. if that is good than go up.
you need to clean out the setting on the laptop first.
delete all of the network that the laptop can find. do a fresh search. click on the router you want ot connect. if you setup the WEP. it will ask for a pass key type in the key exactly as you have on the router (case senstive).
let me know if you need addtional info.
Nov 07, 2008 | Computers & Internet
D-Link 514 model
the key number will be listed in the router settings as you must have security enabled in the router, if you cannot find it then simply reset the router at the rear of the unit and start again as there will be no security key number and all the settings will be back to factory default.
Oct 23, 2007 | D-Link DI 514 Wireless Router (DI-514)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
52 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
