Question about Nikon Coolpix 4500 Digital Camera
Can't get signal to TV with AV cable
My Coolpix 4500 did not have an AV cable, so I purchased one online. I can not get any signal to a TV set with it. I tried the 2 video modes per the manual and a couple of different TVs, with no luck. I am following the directions in the manual exactly with no success. The camera acts like nothing is plugged into the AV output jack.
Thanks
  • 4 Answers
May have a proprietary cable format. try switching up the colors on the TV end (red to yellow / white to yellow.)
may work, depending on the cable you bought.
Posted on Dec 10, 2008
I want to buy a AV cables for a initial 37 inch dtv-372 (db-4500
Hello
AV cable can be bought from most of the electronic spare part selleing shops at your town. It will look like this.
Nov 14, 2011 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
My psp3 turns on tv says no signal with blue screen all plugged in correctly so no picture tried on another tv same problem ?
If all cables are plugged in correctly and your playstation is turning on, your AV cable may be broken. AV cables are inexpensive and can be purchased online from websites like Amazon.com
Jun 13, 2011 | Video Game Consoles & Games
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
When I connect my magnavox blu ray player to my soyo 32" lcd hdtv with audio video jacks my tv screen reads no source. how do I resolve this proble
Purchase an HDMI cable for excellent quality sound and pictures. I suspect the A/V leads will work if you set the TV to the AV channel that is assigned to the AV sockets otherwise you will get a blue screen and no signals.
Hope that clears your problem.
Nov 07, 2010 | Soyo DYLTO32C 32 in. LCD HDTV
How do I hook up a Samsung CXJ1952 to a DVD player? Does it need an RF converter to turn the RCA plug signals into coaxial cable?
it should be the other way around if the tv has av inputs then hook the two units up using av cables if the tv does not have av input then youl need to purchase a rf to av converter
May 15, 2010 | Samsung CXJ1952 19 in. Combo
No signal to tv
your av cabeles could be on the wrong setting try to change from hdmi to tv on the end of the av cable that goes into the xbox. if it still dosent work then try to change the imoprt slots or try your cabels on another tv to see if its your cables thats the problem if you get signal on the other tv then its your first tv. but if you dont your av cabels mite be going i sugjest buying a new set if the other options dont work
Dec 11, 2009 | Microsoft Xbox 360 Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
Nikon coolpix 4500 uv lens
I bought a 4 lens kit - I think from Amazon. It was a long time ago.
The size is 28mm.
yes, here it is
http://www.amazon.com/Nikon-28mm-Filter-Set-Coolpix/dp/B0000521B9
Oct 14, 2008 | Nikon Coolpix 4500 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
60 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
