Question about GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven JVM1440 Two weeks ago after I press 6-express cook stopped and all the lights and clock went blank. In a 10-15 minutes it came back on and the clock would have to be reprogrammed. Thank you
  • 2 more comments
  • SOFYA MINKOVA Nov 10, 2008
    Good Morning,
    Thank you for your prompt response.
    Yes it looks your diagnose is wright.
    The problem is still exist. My oven works not more than 4 minutes, then it should cool down and
    the power is turned back. After this the clock would have to be reprogrammed.
    What is the solution of this problem.
    Sofya
  • willjenn8800 Nov 29, 2008
    I am assuming that my microwave is over heating and shuting down - I really only use it to re-heat and occasionally cook baccon. I can't cook in it any more. After 6 to 8 minutes (combined times) it will stop working. After it rests for 20-30 minute it will start working again. It has been doing this for 6 - 12 months (can't remember when it started), but seems to be getting worse. Is it worth trying to fix?
  • William Miller
    William Miller May 11, 2010
    It sounds like the magnetron overheated, tripping the magnetron thermostat. Then when it cooled down, the power was turned back on.
    This protects the magnetron from overheating.
    Overheating can occur if the internal cooling fan fails or if the magnetron is bad, or if it is run without anything inside or run too long, especially with something like popcorn or baked potatoes.
    Does this sound like what happened?
    How is it now?
  • William Miller
    Did this happen just once?
    It sounds like your magnetron overheated and triggered the thermostat, which shut down power until it cooled down.
  • GE Master
  • 9,098 Answers
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | GE JVM1440 Microwave Oven
GE Spacemaker XL Microwave Oven Model
Your membrane keypad is wearing out.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
The keypad is part number WB27X10171 and you can get it here for $91.68 plus shipping.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Jan 30, 2010 | General Electric Microwave Oven
We have a GE Profile Spacemaker XL 1800. It began making a laboring noise and stopped cooking at the same time.
Sounds like the Magnatron or the HV Cap or diode is failed. Process of will show you which one. Very dangerous area to work in, not for the untrained. Eric
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Glass turntable won't turn - spacemaker - XL 1400
Most likely a bad turntable motor - check with www.martinmicrowave.com for a replacement .
Dec 23, 2008 | GE JVM1440 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
958 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
