Question about Compaq Presario Notebook
Pp1020 harddrive at the mo i have a 5 gig hard drive what is the max size that will fit my laptop and where can i buy.hope you can be of assistance.
  • doug160451 Nov 07, 2008
    would 5gb be of any use just to surf.yes it is an older laptop.
    Problem Solver:
  • 13 Answers
Hi doug160451,
Could you please post the specifications of your laptop, but if your laptop originally came with a 5 Gb Hard Drive then chances are it would be an old laptop and you would do better upgrading to a new laptop than go through the problems associated with upgrading only your hard drive.
Cheers
CptHaddock
Posted on Nov 07, 2008
  • Joshua Wong Nov 07, 2008
    5Gb of Hard drive space is fine, but normally laptops with a 5Gb Harddrive would have Windows 98 or 95 on it. This implies a couple of things.
    1. At that time you had to do a few special things to allow the OS to see past 2Gb of Hard Drive space. But I also think the latest IDE 2.5" drives are now fast becoming obsolete.
    2. If you are running Win98 or 95 the preloaded microsoft Internet Explorer web browser is nolonger supported, therefore running flash and java is not going to work either. You could try downloading alternatives such as Opera, where the earlier versions will work and apparently version 9 as well.
    http://arc.opera.com/pub/opera/win/
    At the moment it's hit and miss as there are alot of things on the web that require flash and java and .net support.
    Sorry, but your web browsing experiance may be a limited one on an older laptop.
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
N800v harddrive blew out
It depends upon your needs, the larger the hard drive to higher the cost and the maximun size you can install depends upon the BIOS. The smallest hard drive that is readily available is about 100Gb.
Jun 15, 2009 | Compaq Evo N800v Notebook
Hardrive upgrade on IBM i 1400 Laptop ?
Hi! It's correct that your Thinkpad will only accept up to 512 mb of memory, and only certain chips will work with your unit. Here is a link that shows the memory that will work.
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=-1192&pid=399
Below is a link for recommendations for a hard drive upgrade. It looks like you can go up to a 250 gig drive using Western Digital. Hope this helps! Hal
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch3&model_id=-1192
Jun 05, 2009 | IBM Thinkpad I1400 2621 Planar TV...
My sony vaio s460 does not detect the hardrive, after I installed new 120 gig sata, I called to sony and they said tha I need the same hardrive 80m gig 5400 rpm, as the laptop comes from factory, it is...
It may be that your machine can not handle a drive of that size. When I replace hard drives I always try to replace them with the size they came with just in case they do not support a larger size.
Dec 18, 2008 | Sony VAIO VGN-S460 Notebook
Know what kind of hard drive to put in a toshiba satillite 4090
It will If its a laptop sized hard drive , A desktop sized Hard drive will not fit.
Nov 30, 2008 | Toshiba Satellite 4090XDVD Notebook
Pp1020 ram
Hi Doug-
Your Compaq Presario 1020 comes with 16M RAM and can be upgraded to 48M total
(by adding a 32 MB EDO RAM 5 volt SODIMM in the single available memory upgrade slot)
Nov 05, 2008 | Compaq Presario Notebook
Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
May 30, 2008 | Acer Aspire 5100 Notebook
Bios won't reconise 160 gig maxtor harddrive
You could try a BIOS update to increase the size of the Drive the BIOS is able to see.
The second last one indicates that drive sizes are supported over 65GB. It may still not be able to see the 160GB HDD, but this is your only option with this Board. You could always upgrade the Motherboard to support larger drives.
Good Luck.
Apr 24, 2008 | Maxtor HARDDRIVES Hard Drive
Cannot copy large files to drive
Your external drive is formatted for FAT32 which only will accept max 4GB transfers. Try NTFS format. Take a look at page 47 on this file then go from there. Hopefully this helps. http://www.acomdata.com/AcomData_Downloads/3.5_External_Hard_Drives/E5_Series_Hard_Drives/HDxxxSE5-72-PCI/M-HDxxxSE5-72-PCI-v1E.pdf
Jan 11, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Compaq Presario Notebook Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
