Question about Sylvania SRT4127P TV
Sylvania 27" TV
Just recently my Sylvania 27" tv, when turned on, only shows a thin line on the TV screen.
  • Terri Fryberger Oct 18, 2006
    Thank you :) how pricey would this be to fix? Or are we better off buying a new TV? Our warranty and MRA expired about a year ago.
  • johnandjay Mar 16, 2008
    Turned on 27"Sayno and a 3/8" vertical line is all that appeared . Sound was fine. Tapped the side of the set and the picture came on full screen for several minutes then reverted back to just the thin line and has remained that way.
Replace the yoke return cap. Its a polyester cap. probably 0.33uf and blue. trace back from the yoke connector plug pins. Other than that, look for bad solder on the yoke plug.
Posted on Jan 24, 2007
    Novelist:
    Champion:
  • 236 Answers
Your vertical output IC may be bad or have a loose solder joint.
Posted on Jan 12, 2007
Vertical out ic bad. follow power line back to horz. sect or ps. maybe a burned resistor that went also.
Posted on Jan 11, 2007
    Scholar:
  • 68 Answers
A vetical timebase failure like this is not bad and should not take a Serviceman long to fix if he has the all important service sheet, or circuit diagram and an oscilloscope. Line/horizontal timebase failure is much more serious, as this is the primary source of power and would cost more.
Posted on Oct 19, 2006
    Sergeant:
  • 337 Answers
The set is having a problem in the vertical deflection circuitry,the one in charge of opening the picture up and down.Sometimes the output IC developes loose conections and sometimes the IC just goes bad,if you tap the set on the side lightly and it reacts it might only be a loose conection. If you are familiar with tv service you have a place to start but if you are not too familiar be safe and call for assistance from a servicer,it should not be expensive if you take it to the shop.
Posted on Oct 18, 2006
  • Omar Urrutia
    Omar Urrutia Oct 18, 2006
    Your rating response is also important.
  • Omar Urrutia
    If the quality of the picture was good when it failed it is worth the repair.
    President:
  • 3,130 Answers
This problem sounds like the vertical output circuit is bad. it could be a vertical output IC, a bad resistor in the sweep supply, a bad capacitor, or a bad solder connections. Sorry to say this is a solid state set, so if you know how to solder and know how to service solid state devices, you should have No problem finfing the bad part. if you have no experience, please be safe and call in a trainede tech to assist you. Good Luck PS please dont forget to rate this thread>
Sylvania tv gets thin line where picture should be. Problem comes and goes. What is this?
The problem is in the circuit board, there are bad solder connections near the high voltage transformer and the vertical deflector ic. If you are handy with a soldering iron unplug set, remove the back cover, "several screws" and check the underside of the board on the right side, when in dought touch up with soldering iron.
Jun 20, 2011 | Sylvania SRCD227 27 in. TV/DVD Combo
Our 27" Works for a
The thin line image appears when the vertical deflection unit is not operational. This is a major fault for which you will have to take the tv to a repair shop - several components (starting with the vertical amplifier) will have to be replaced. In the mean time do not use the tv, or it may fail completely.
Mar 16, 2011 | RCA TruFlat 27F520T 27" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
No audio and have a thin white verticle line across tv
Always suspect a bad EEprom...very common on this TV! See a tech, he will have to select one of six eeproms to fix this!
Jan 10, 2010 | Philips Magnavox 27MS343S 27" TV
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
Lcd tv screen shadow
they call that line pixels and the only way to fix is a new lcd panel. if you have under 8 pixels your warrinty won!t cover with some companys
Aug 31, 2008 | Sylvania 6427TE 27" TV
A bright thin white line, side to side.
You need to replace the vertical IC and all the dry capacitors near to him.Good luck
Jul 06, 2008 | Sylvania 202SL8 TV
32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
Dan
May 07, 2008 | Sylvania SRT2232S 32" TV
27" sylvania stereo television
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Jan 26, 2008 | Sylvania 6427TE 27" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Sylvania SRT4127P TV Logo
215 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
