Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax function I have had my 6110 for several years. It has worked flawlessly. We moved. Our new house is prewired with a structural central phone/internet/television system from Comcast. Every time I plug in my 6110 it freaks out the system and I lose all telephone function throughout the house. I have to push a reset button on the phone routing box in the basement. Have you heard of this problem before? Should I contact Comcast?
  • Anonymous Nov 15, 2008
    I have hadmy HP 6110 for years. No when I go to fax something I do not get a dial one. I change cables and plugged it directly to the wall, still no dial tone when faxing.
    Help,
    Thank you,
    J
    Novelist:
    Scholar:
  • 111 Answers
I looked at the Comcast site and searched for "fax problems" and discovered that, although you can fax using their service, some devices are incompatible. However, when I took a look at the list of devices, no HP products were listed.
Do fax machines work with Comcast?
Incompatible Equipment
That said, the service you have subscribed to (central phone/Internet/TV) may had additional issues with faxing. I'd have to say "yes", please contact Comcast support to see what can be done to resolve this issue. There may be a filter box or some other device that has to be installed so the fax machine can detect a dial tone without all of the other data on the line and avoid "freaking out" your system.
Here's the link to their Help and Support page. Good luck and post back your results:
Comcast Help and Support
Posted on Nov 10, 2008
Central home network
(add small 4 port hub) from cable router out to hub port 1.-take cat5 from central insert in port 2 of hub.- insert cat5 in port 3 of hub then other end in now open cat5 port
Jan 03, 2010 | CommScope 1000 FT RG6 QUAD/CAT - 5E 4 -...
Unable to scan or fax. I have a HP Officejet 6110 all-in-one printer, copyer, scanner and fax machine. I have never used the scanner and the fax simply stopped working after years of service. The printer...
Thanx for contacting in fixya....
u need to uninstall the printer software and then reinstall if this problem persists again format ur system c driver it is the only sure solution
regards
john symester
Nov 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I was given a new light blue Gaggia 'Francis Francis' machine ten years ago. I used it pretty regularly, then put it away during several house moves . I'm trying to get it working again now, after 5...
valve in group head seized. remove 'shower' under group head with central screw remove internal spring loaded jet clean and re-install. Then run a de-scale.
Sep 19, 2009 | Coffee Makers & Espresso Machines
Fax set up -I've used this model for years and now
do you have dsl filters installed? the fax should go to unfiltered line not the filtered dsl line.
Jul 17, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Setup fax machine with new telephone number
no change is needed for incoming faxes (it your new number) and the person (s) on the outgoing side will see the new number also....so just connect it correctly and happy faxing
Mar 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Fax set up
You can download this for free directly from HP with no hassles or signups required:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=79477&lang=en&
Mar 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
CAN'T GET FAX TO WORK
turn off answering mech. count # of rings before fax answers add onemore ring to answering mech. before it answers.
Dec 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one
need down lod program fo officejet6110all-one
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
ClickSmart 510 Will Not Be Turned On
make sure the terminals the batterys go into arent dirty, thats usually one of the main reasons a camera wont function. hopefully it works out, good luck
Aug 23, 2007 | Logitech ClickSmart 510 Digital Camera
HP OfficeJet 6110 All-In-One InkJet Printer Logo
119 people viewed this question
Ben Johnson
