Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP Officejet 6110 xi All-In-One will not scan
At my job we have the 6110 xi all-in-one model. Usually we scan documents onto an old Windows laptop, but I decided today to install the driver files for the 6110 xi onto my Macbook and do it that way since it would be faster.
The problem is now that when I tried and scan again with the old Windows laptop, the 6110 xi still thinks its the Macbook. So when I'm pressing the "Scan to" button the options that come up aren't: Scan to paint, word, email, etc. It shows: Scan to adobe photoshop, scan to mac mail... AND I CANT FIND A WAY TO CHANGE IT BACK.
It won't recognize the Windows laptop. Even if I work around and try to go to Microsoft Office tools and use the Scanning wizard and even when I select scanning from the Scanners and Hardware spot in the Control Panel, it still won't. I'll start the process and it will say "warming up lamp" and then it never gets past that. Furthermore, the HP Director won't open on the laptop.
Somebody help, because I can't keep my Macbook at work just so we can scan documents.
If this doesn't make a whole lot of sense (because I've analyzed this so much myself and come to no solution, which is why I'm here) I will try to explain it better.
Thank you
  • 1 more comment
  • Jacob Nov 10, 2008
    No, this isn't complicated it makes a lot of sense. I could not find the original CD in the office so that added to the frustration. I tried installing various different drivers on the Windows laptop, but it did nothing. Perhaps a full uninstall is necessary. Also, I unplugged the Officejet 6110 xi, but I don't think it was longer than a couple seconds. I'll try for a minute or so and then see what happens.
    I'll post back with results soon. THANK YOU!
  • Jacob Nov 11, 2008
    Ok, I came into work today and immediately unplugged the Officejet for about 2 minutes. When plugged back in, still no changes. However, I uninstalled the software and drivers from the Windows laptop and then reinstalled the newest versions of them from the HP support site. Everything now works as before.
    Thank you so much.
  • evanr Dec 12, 2008
    My 6110 Officejet won't scan. I tried downloading the software and re-installing, but still nothing. Can I get a new CD software? Can't find the original CD.
    New Friend:
I've had the same problem for months and it is now working. I solved it by unplugging the USB from the printer AND the computer and unplugging the power cord as well. I let it sit for 5 minutes. I had read a previous solution that said something about letting the brick dissipate?? I then plugged everything back in. Turned the printer on and it immediately installed itself. Then I went to Control Panel, Device Manager, Imaging Devices (may be worded a bit differently) right clicked on my printer, clicked on update software--it took several minutes for it to find the update, so be patient, but when it did it updated quickly and now the scanner is working. :) I tried several other suggestions, but this is what it took to get it to finally work!
Posted on Nov 10, 2013
    Novelist:
    Scholar:
  • 111 Answers
This is an interesting problem because a printer isn't "intelligent" the way a computer is "intelligent". While devices such as the 6110 have RAM and thus "memory", they don't have the ability to recognize which devices are connected to it, as such. That's why you have to install all of the HP software and drivers onto the Windows or Mac machines, so the burden of recognition and interfacing is on them.
That said, information and even errors can be stored in a printer as long as it's receiving power...sometimes even when they're turned off.
My first suggestion is to completely turn off the 6110 and unplug it both from it's supply of power and from any computers.
Let it set for around 30 seconds to a minute so that any residual power from the "brick" dissipates.
Reboot the Windows computer.
Then plug the 6110 back into it's power supply and attach it back to the Windows computer.
Power up the 6110 and let it go through it's start up and alignment routine.
Try to scan again as you originally did before you tried to us your Macbook with the 6110. Hopefully that will do it.
If, for some reason, the Windows machine is still not able to interface with the 6110, you may have to completely uninstall all of the HP software and drivers from the laptop and reinstall them using the original installation CD, just as if you were installing the printer with the laptop for the first time.
This means (assuming you have Windows XP), going to Start -> Control Panel -> Add or Remove Programs. You'll need to go through the list after "Add or Remove Programs" opens to select and uninstall all the software and drivers that have anything to do with the 6110. Hopefully, this'll be just one or two selections.
If you have the original CD, you can also insert it and it should offer you the option to uninstall the original software and drivers. That would be the easiest. Then you could just turn around and do a reinstall from the disc, no muss, no fuss.
If you do not have the original CD (and believe me, these things get lost all the time), you can still download all the latest software for the 6110 onto the Windows laptop by going to this web page at HP.com:
Officejet 6110 Software and Drivers
Once you go to that page, you'll need to select your particular Windows operating system name. You'll be taken to the web page where you can download the installation software and the latest drivers. Once they're reinstalled onto your system, you should be good to go.
You "may" be able to install the latest software and drivers without uninstallng the old stuff first (that is, you could be offered the option to overwrite the old software when you install the newer software),. but that's not as "clean" and instead of curing the problem, it could make it worse. If you're a risk taker, go for it. If not, don't take the chance of more headaches.
I probably made this sound more complicated than it is. Good luck and post back your results.
Posted on Nov 10, 2008
  • tripwire45 Nov 11, 2008
    Glad I could help. I appreciate the feedback. Cheers.
    -Trip
Officejet 6110- do display/needs attention light on continuously
try this
turn on/off, unplug, plug in, should reset configs. might have to do this a coupe of times
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
hope this helps and good luck
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
It will not scan. It copies and prints but it will not scan.
I had the same problem-- reinstalling the software with no results. I hooked the printer to my old laptop which had worked with the printer in the past and was able to scan. I installed the "HP Solution Center" which came with a newer printer onto my new 'problem' computer. It recoginized the 6110. I re-set the buttons on the scanner and it has worked since.
Looks like it is a 'driver/program' problem between the printer and computer.
Hope this helps.
Jul 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't find how I initiate a scan on my HP 6110 all-in-one
I suppose there was a problem in your driver installation. For most USB devices, it is recommended that the drivers be copied/installed on the pc prior to attaching it via the cable. So, if you attached the printer to the pc before copying its driver to the hard disk, you are likely not to have the right result ok. Put back the driver cd/dvd into the drive tray and uninstall. Restart your pc and then follow the step above. Good luck
Jun 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
Mar 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning
Try using the scan program provided by Hp already installed in your computer.
Double click on "My PC" select the OfficeJet scanner icon and do a the right click, and then order to a scan.
Oct 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Installing hp officejet 6110xi onto my laptop
Click here, enter required details, follow instructions and download software from HP website.
Oct 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
916 people viewed this question
Ben Johnson
