Question about Relisys TL 766 Monitor
Blue box I have been given a flatscreen monitor which on installation has a blue box in the middle of the screen saying "Input signal out of range". How do i remove this?
You need to set the screen resolution or refresh rate of your windows. I am assuming you have XP.
Start your computer in safe mode (press F8 persistently at boot up)
Select safe mode
  • In windows, right click on a blank area of the desktop.
Left click on properties
Left click on the settings tab
Move the screen resolution slider fully over to the left.
Apply, and OK.
Restart your PC normally now.
If you get into windows OK you can repeat the above procedure from the bullet point above, but this time move the slider to a screen resolution that suits you.
If this doesnt solve the problem it may be the refresh rate, if so, when you get to the line where you click on the settings tab, then click on advanced. Select Adapter or Monitor and reduce the refresh rate to 60 or 70 hz. Apply and restart.
If you are STILL struggling, put your old monitor back on, set the screen resolution to 640x480 and 60hz as per the above instruction in normal (not safe) mode. Then shut the PC down and re-attach your new monitor. The reset the screen resolution back up.
Good Luck
Posted on Nov 07, 2008
How do i fix only sound and a blue screen
that's strange ?? a blue screen , I say strange as this tells one that the monitor functions are working , blue screen is self generated to keep monitor biased to display a signal , me Id be looking real careful at input sources and input jacks , id be especially suspicious if there on a separate board off by them self's with only cables between them
Jan 30, 2016 | Televison & Video
When i switch on my baird 37 inch flatscreen the screen is bright blue
The blue screen usually means no signal of any kind--check connections.
Also look to see if a DVD etc. connected to a rear audio/video input works or not--this will narrow down the area where the issue is.
May 16, 2012 | Televison & Video
usually points to the resolution settings of the graphics card not matching the monitor resolution settings. Reboot to safe mode on the computer and set the resolution to a lower one. A good starting point would be 1280 x 960 at high res. See if that works
Jul 09, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
My settop box has given me a blue screen and now i
A Blue Screen, means that there is NO signal be "Given" to the "Input" that the TV is currently using. Try another "Input" or check your antenna is OK, you are "ON" the right "Input" too.
Mar 02, 2010 | Televison & Video
How to remove "no composite inpute signal"
If you have the same problem with both monitors, it sounds like a display card setting or problem.
The chances of you having the same problem with different units is 1- 50.
Try the monitors on a different PC and get back to me.
Sep 02, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
Jun 26, 2009 | Hyundai Electronics E465D 46 in. LCD TV
Monitor problems
Try setting your resolution lower via the control panel; it appears the resolution picked by Windows is beyond the monitor's capabilities.
Dec 13, 2008 | LG Computers & Internet
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Relisys TL 766 Monitor Logo
121 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
