Question about Toshiba Computers & Internet
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
    Top Expert:
  • 5,051 Answers
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Posted on Mar 26, 2012
SOURCE:
paul7of9
  • 1189 Answers
SOURCE: My screen fails to illuminate, I can make out text
  • Hi, hope this will help you with your problem. There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Select, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "Restart "Computer." *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Posted on Feb 02, 2010
  • 387 Answers
SOURCE: my Toshiba a200 laptop doesn't
It look like you have another portable of the same type If you have the same problem trying your adapter on the other laptop it will be a good indication that the adaptor is deffective
Posted on Aug 01, 2011
  • 586 Answers
SOURCE: My Toshiba Model L505-S5993 laptop won't read
Hello there,
The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
Hope this was helpful to you.
Goodluck
Elect_Comp
Posted on Aug 09, 2011
apark109
  • 107 Answers
SOURCE: My computer laptop model is
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Posted on Aug 27, 2011
shandogar
  • 360 Answers
SOURCE: i have my compaq laptop
Reassemble the battery once more and charge your laptop via stabilizer.
Posted on Sep 10, 2011
Where can i get a Toshibia L300 satelite Windows Vista Rebooting Disk to reset the laptop? as i cannot find the one that came in the package with the laptop.
Toshiba usually doesn't include the recovery as you would have to create one for yourself.
If you're having trouble finding it and you cannot boot the computer anymore my suggestion would be to contact toshiba and order a recovery disk. (it's part of their business and it sucks bigtime).
You can also create a windows installer using a USB you can youtube how to do it for video instructions.
If you can still boot from the computer go to control panel and that is where the program to create the recovery disks is.
Hope this helps!
Sep 11, 2011 | Toshiba Satellite Pro L300 Notebook
Hi! I have a Toshiba Satellite A305D-S6848 and can't find the number lock button. Can you help?
Hi.
That particular Toshiba laptop model doesn't have a number lock key. You have to hold down FN and then use the letter keys with numbers printed on them.
Regards.
Jun 03, 2011 | Computers & Internet
My power charger cord will not charge my toshiba laptop anymore. I need this computer for school everyday. please help.
If the charger is good, the battery may not be. If they are both good, the motherboard has a big problem. You need a multi-meter to check the power output of the charger. The battery is too complicated for me to explain how to test it, just try replacing it with one off ebay. If it still doesn't charge, it's the motherboard. That I can tell you can't replace on your own. It would be cheaper to replace the laptop & have all your critical files transfered.
Apr 30, 2011 | Lifetime Toshiba Satellite L355S7835...
Where to get wifi driver for my Toshiba satellite PSL2XU-00Q00D wifi driver
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Nov 29, 2010 | Computers & Internet
My screen fails to illuminate, I can make out text just barely but there's no light - I think it's the inverter? If so I found one to buy but I'm looking to at least see it in my laptop first, is it...
Feb 02, 2010 | Toshiba Satellite L25-S119 Notebook
WHAT IS THE IP ADD FOR SATELLITE L25-S119, MODEL PSL2XU-00J00D
go to internet connection, right click on lan and select properties and go to tcp/ip and restore to default (automatic)
Dec 30, 2009 | Toshiba Satellite L25-S119 Notebook
Satlite l25-s119 i need all drivers for the above model laptop
Hi!
Here you can find all the windows drivers:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1124512&rpn=PSL2XU&modelFilter=L25-S119&selCategory=3&selFamily=1073768663&selModel=1124512|PSL2XU
Jan 19, 2009 | Toshiba Satellite L25-S119 Notebook
Service manual
what do you need to do? did you try www.repair4laptop.com and other sites like that?
you can try this site too.
http://www.free-service-manuals.com/Computers___Software/Notebooks___Portables/Toshiba/index.html
Nov 14, 2008 | Computers & Internet
Computers & Internet Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
