Question about Poulan Garden
  • 52 Answers
Hi joeted3,
My name is Dennis and I am here to assist you with your problem.
Please don't be offended with this answer because it sounds so basic but it happens to us all when we are in a hurry. That's the key phrase "in a hurry" with no more information that is described I will venture a few possibilities.
1) If the chane came off and was replaced and the saw stalls when you try to cut it's likely that the chain was bent slightly when it came off and it's binding in the groove of the bar.
2) If the chain came off and it's not binding in the bar, runs smoothly and should cut like crazy but dosn't, look at the image of the chain on the plastic cover of the drive sprocket near the bar adjustment nuts and note the angle of the teeth displayed. The chain may be on backwards, don't tell anyone but it happens to us all when were in a hurry.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Posted on Nov 09, 2008
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
New Homelite. Cut great for an hour, then the chain wouldn't grip or cut. Chain was loose so I tightened but still doesn't cut- just
The blade is no longer sharp, something not unusual after about an hour of cutting. How long a blade stays sharp depends on what type of wood you're cutting, whether the blade contacted the ground or anything other than wood at any time, and how hard you are working the bar through the wood. If you are cutting hardwood or something like railroad ties the lifespan of the blade is greatly reduced. You can easily sharpen the blade with a hand file or dremel tool with a chain saw blade kit on it or have the blade sharpened. Best practice is to have one or two extra blades so you can change them as they become dull.
Mar 29, 2012 | Homelite Garden
My saw threw a blade . I took it apart to put the blade back on I have tried everythingbut the blade ,which is the proper one isI about 1-2 links too long. this is w/ the tensioner all the way out. Any...
I would say that it's time for a new chain. After using for varying periods of time the chain will stretch too far to be used anymore. This is caused by heating during usage. Some things that will cotribute to chain wear out are insufficient bar oil, dull chain or just every day wear. I think if you get anew chain you'll be fine. When I'm tensioning my chains I run the saw at high rpm for a couple of mins. Shut off and grasp chain by mid-point of bar and lift up. I try to get enough space to slip a nickle between bar and bottom of chain. You should check tension often, as over tightening also adds to wear on chain and motor. Hope this helps you. Thanks
Nov 14, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Saw cut is not straight. It curves until it freezes the chain.
Hi, sounds like the blades on the chain are either blunt and need sharpening, or they have been sharpened at the wrong angle.
Hope this helps
Sep 06, 2010 | Poulan Pro Chain Saw 46cc 20"
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I just bought a Poulan 16'' chain saw with quick adjust chain tensioning. The chain seems to loosen after a short time of use and the chain comes off. Quite disturbing.
1. It is common for a new chain to stretch. that is probably what occurred
2. I'd hold the tip of the bar 2-3" above a stump or even a news paper, rev it up for a few seconds and look for a line of bar oil. If none is visible your bar oil reservoir is empty or saw isn't oiling. If you added oil and it's not oiling return it to where you purchased it.
Sep 08, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try
Mar 04, 2009 | Poulan Pro Chain Saw 46cc 20"
My chain saw
you need the correct size line, it comes new yellow colored now , claimed to be more impervious to gasahol -with a razor blade , cut the end of the new hose on a long enough angle to feed it thru the tank grommet, then you can grab it thru the tank grommet with medical locking forceps - its a snug pull thru the grommet but easy - hope this helps
Nov 21, 2008 | Poulan Pro Chain Saw 46cc 20"
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Garden Logo
144 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
