Kenmore Elite 20992 washing machine not spinning
Model: 110 20992 991
Type: III
My husband and I have been problem shooting this for a week. The washer will agitate and drain but does not spin dry. We read online that it might be the coupler so we disassembled and looked at this part and could not see any problems. If a coupler is broken is it visible to see or is it internal (in the engine or elsewhere)?? The 3 leg/3 leg and rubber ring ("spider" piece) did not have any broken legs or parts that seem lose.
We put it together again and tried a cycle to troubleshoot. It fills, agitates and drains but does not spin. It makes a whirring noise like it's trying to spin and I don't believe it's the engine. It also begins to smell a little like burnt rubber when it gets to the spin cycle. Any ideas? Please help....Thank you so much for your time.
Michelle
  • Anonymous Nov 19, 2008
    Exactly the same problem.
    This one had a definite rattle whine it tries to enter the spin cycle.
    It's at an apartment, so I'll take it apart.
    Anyone have a diagram?
SOURCE: Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Posted on Nov 24, 2007
Oceti
  • 51 Answers
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
Posted on Dec 07, 2007
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
  • 1294 Answers
SOURCE: BACK LEG LEVELING ARM
The back legs are usually not adjustable. Adjust the front legs & lock them with the lock nuts, at the lowest level, that is the machine tilts towards the front. Adjust further if there is any shake when you try with your hands.
You could also check to see if any springs or shocks have become loose. Refer manual.
Posted on Mar 30, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Kenmore oasis elite dryer trouble shoot f-24 error kenmore
According to the manual, follow these steps:
  • For an "F" error on your Washing Machine.
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select DRAIN & SPIN if there is excessive water in the washer.
  • Re-select cycle and press START.
  • If the problem remains, call for service.
Here's the full manual: Kenmore 110.45986400 Owner's Manual
Jun 15, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
The washer shakes to much and make to much noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Jul 21, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite washing machine-wont spin
remove the lower panel. it is held on with 3 1/4 inch headed screws. With a pail to catch the water, remove the clean out cover. Ifr the clean out is plugged, the washer will not drain.
Jul 25, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Elite #20992 can't remove back housing
Comes apart from the front. 2 screws on front of control psnel; flip it up. 2 clips to pry out; also ulplug lid switch. Cabinet lifts up from back and comes right off. Hope this helps!
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
