Question about Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony with diagonal lines
My sony has diagonal lines accross the television on the input #4, which is where cable is. There is no adjustment in the menu that corrects this. I have turned it off and unplugged it several times and this continues. It does not appear on other video areas where the dvd player is working etc.
  • 304 Answers
Plug your DVD player into input 4 to diagnose if the problem is with the TV input or the source. If the DVD player works fine in the #4 input the TV is fine. Now plug the cable box into the input where the DVD was plugged in and known to function well. It the problem now exists on that input you know it is either the cable box or the cable itself that is bad. A bad cable will cause diagonal lines. Try replacing the cable with the good one from the DVD player. If it is the cable simply replace the cable with a high quality cable. Cheap cables are the cause of these problems 95 percent of the time due to poor sheilding in the cable allows transient signals to pass to the input causing the diagonal lines. This should help you fix your problem. If toy need more help feel free to contact me.
George
Posted on Aug 05, 2008
?My sony has diagonal lines accross the television on the input #4, which is where cable is. There is no adjustment in the menu that corrects this. I have turned it off and unplugged it several times and this continues. It does not appear on other video areas where the dvd player is working etc.? It is happen right away when you firth turn it on or after 5, 10 minutes? Look like the tuner or PLL module are bad ground on some coil (L). Try to re-solder the entire coil inside Tuner module and PLL control module. Warning: If you not sure what are you doing then hire a qualify technician.
Posted on Oct 18, 2006
    President:
  • 3,130 Answers
Is it a composite(yellow plug)video input? an HDMI input? What if you switch the output of the cable box to another input, Make sure its not the cable box first. If it happens on another input then the cable box or the connection wire to the tv from the cable box is bad.Good Luck Ps Please rate this thread
    Scholar:
  • 68 Answers
This sound from your description like the `line hold' is not locking on from the synchronising signal. The synch pulse, which is at the start of every line scan, is generated by your cable company/box or your DVD player, or whatever input device you have chosen. It is possible to loose this signal from certain video inputs due to the level/amplitude being too large or too small. Try a 50 ohm in-line attenuator of 6dB or 3dB or 10dB (can be made up of resistors) in the input cable. If you have a friend with an oscilloscope he will look at the synch pulse for you.(on the attenuator).
Posted on Oct 19, 2006
4 Suggested Answers
  • 395 Answers
SOURCE: Connect Apple TV to Sony 27FS100
the kv27fs100 is a standard 480i resolution check the output of the apple tv make sure it is not in progresive 480P
Posted on Feb 27, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
SOURCE: My sony trinitrion always displays the video
Using the TV's remote and having the TV on,
hold down the "reset" button and manually turn off the TV directly from the unit.(not the remote)
Release the "reset" button.
Turn the TV back on-directly from the unit.(not the remote)
A dialog box will appear on your screen.
Choose "Auto" by pushing the + on Channel Selection button on the unit (not the remote).
Use the TV/DVD selection to return to your cable input.
Posted on Aug 02, 2010
We have a Sony Grand Wega KDF-50A10We just started having an issue with verticle lines in the picture that extend from the top down about 1/3 of the screen. There are similar diagonal lines on the bottom...
It will be best for you to visit the site linked here. It has screen-shots to defective LCD screens, and details about the faults. You can compare them to that of your TVs' and can determine the cause of the fault. If you wish to get more details, check this. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 29, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony kp-51ws500 that shuts off and blinks 8 times, I'v read that some other people have had the same thing and it was the flyback transformer. Now my tv has just a green screen with no pi
No, the set is prone among other things to issues with the three picture tubes, go to unused video input----screen should be black with only the input label displayed-----in your case with Green screen and or slight diagonal trace lines (if there) the Green screen control itself needs to be adjusted slightly down.
I can tell you if you want how to do that---requires only a screwdriver and 10 minutes.
Dec 03, 2012 | Televison & Video
Very faint red line down the side of tv
I would on the model listed first go to a video input that is not used and look to see if line is there-----this model is prone to bad picture tubes but that usually gives diagonal lines that can be seen in the background or on that unused video input.
Aug 29, 2012 | Sony KP-57WS500 57" Rear Projection...
My sony bravia 46' KDL3000 upon start up has horizontal lines going accross the screen that make the image blurry.after quite some time it seems to clear itself up and go away almost like once its warmed...
sony lcd blury when we view satelite its common samsung and panasonic give good pitchure then sony bravia tey some good monster cable it will give good pitchure
Jan 08, 2011 | Sony Televison & Video
I have a sony kp-51hw40, it started to have blue and red lines accross the screen. now the picture turns blue then turns off. is my red and blue gun wore out?
find someone that knows about TVs to take off the front access cover and adjust the screen controls .DON'T TOUCH THE FOCUS KNOBS.Just the screen control knobs.Usually they can work a few more years with adjustements . But if it can't be adjusted to work then the guns would have to be repaced.Many many many many of your model were affected by a little screw up sony made with their CRTs.
Oct 03, 2009 | Sony KP-51HW40 51" Rear Projection...
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
Nov 06, 2007 | Sony KP-51HW40 51" Rear Projection...
Lines on top and bottom on projection TV
What sort of lines? - do you mean like it is in widescreen mode with a black band top and bottom? Do you mean you have clear straight lines, or streaks or scratch-like marks? Is it the same for all input sources (cable, DVD/VCR, satellite, PC, camcorder etc.? Could you post back a photo of the lines? Waiting your info:)
Jul 16, 2007 | Sony KP-43HT20 43" Rear Projection...
Sony FD Trinitron WEGA KV-36FV27 36" TV Logo
1,532 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
