Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Prints faded I recently replaced my color cartridge, and later the prints were faded. I then replaced the black cartridge also, but still had poor quality, faded looking photos. I did use Kodak cartridges, not a refill. thanks.
  • rosalieb Nov 07, 2008
    I changed the color and the black cartridge and I still get hardly anything on the print sheet. This is a new printer.
I went to the AIO software, clicked on the ?: in the upper right hand corner, under General LInks I sselected Maintenance then chose Clean Printhead and did that twice. Thank YOU for the help,
Baby YanYan!!!
Posted on Nov 11, 2008
  • 25 Answers
Hello mvjv,
To solve the faded prints you need to clean the printhead twice by going to the software and click the "?" mark icon on the upper right corner of the software window and then under General Links select Maintenance then choose Clean Printhead - do it at least thrice to unclog the printhead system. Then try making prints... If still cannot solve call Kodak Technical Support.
I hope I have been some of help.
Posted on Nov 09, 2008
CANON PIXMA COLORS ARE LIGHT
I would manually clean out the printhead, I believe for your model it is a separate unit form the ink cartridge. Please follow these steps bellow.
First you will need to remove the cartridges, then remove the printhead assembly then mix some water and isopropyl alcohol in a 50/50 mixture. You can either use a cotton swab to rub the water and alcohol on the printhead or you can soak the inkjet printhead for around 2 to 5 minutes. This should loosen the dried ink. It may take a few attempts and requires patience. Dry it on a folded paper towel and reinstall it. Print a test page to check quality. If the documents are still printing with poor quality, repeat and soak the printheads for longer.
Let me know if that helped. I had the same issue and this resolved it for me.
Thanks
Bloomfield Connecticut Computers (BCC)
Jan 13, 2014 | Canon PIXMA MX700 All-In-One InkJet...
Faded prints samsung clx3185 fw
Got one clx 3185fn printing black only. even press color copy button.
Cartridges are new. Please advise.
Thanks
mearmi@hotmail.com
Oct 26, 2012 | Samsung CLX3185 AllInOne Laser Printer
Brother MFC-440CN - print quality terrible, almost non-existent in spite of many cleaning operations.
It sounds like the printhead needs to be replaced. Brother may cover the cost of repair if you call them at 877-276-8437 and tell them the prints are "missing black ink". Very common problem that a new printhead should fix.
Oct 08, 2012 | Brother MFC-440CN InkJet Printer
Printer wont print black, it only prints in color, also the printing fades
printing in black
* change the properties of your printer --->> Printer icon-->>Properties-->> select color or black and white grayscale.
fading print
*clean the cartridge printhead through the computer or manually (remove cartridge and wipe with cotton cloth with water). Also, clean the scanner window (glass).
http://printerquickfix.blogspot.com/
Jul 19, 2011 | HP DeskJet 842c InkJet Printer
Poor print quality .... Canon Pixma MP140 ...
Paper quality does make a difference in the quality of print, but it's usually in the areas of blurriness and vibrance. If your prints are coming out faded, the quality for your prints might be set to 'economy', which doesn't use very much ink. If you have it set for 'quality' prints, I would try replacing the ink cartridges.
May 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Color intensity= poor
Shake the cartridges well, it seems that they become dry, try to replace them and check again, go to driver there is setting makes u clean and test the nozzels which makes the color more rich and at the same time it check the state of the cartridges.
Best Regards
Mar 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
A faded line prints across the page
The imaging bar has speck of dust on it.
Turn printer OFF.
Open the printer. Pull out the transfer roller. Should have a big green handle. Do not touch the roller.
Look inside for a shiny rectangular block about 5inches x 0.5 inch.
This is the imaging bar. Using a lint free cloth with no chemical and no water, gently wipe this bar to remove any specks of dust/paper specks.
Put roller back.
Close the printer.
Turn printer ON.
Problem fixed.
May 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
162 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
