Question about Hitachi P50A402 50 in. Plasma TV
New plasma not working
I have no picture or sound. Menu wont even pop up. Blue indicator light on front flashing 3 times
  • 905 Answers
This is most likely a couple of problems inside the unit , will you be trying to fix it yourself?
if so give me a fixya rating and I'll be glad to assist in determining the source of the problems
electech
Posted on Nov 07, 2008
  • jason Nov 07, 2008
    this is going to be one of the boards and you will need to do some tests for me so I can analyze the results
    you will need to check for open protection fuses on the power section and check the voltage on the transformer
    when you get the results post them so I can analyze them , thanks
    electech
WHY WON'T MY HITACHI PLASMA TV SHOW PICTURE OR SOUND? WHAT DOES THE BLUE LIGHT ON THE FRONT FLASHING 4 BLINKS MEAN?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 31, 2016 | Hitachi Televison & Video
Our jvc tv made a popping sound and now has no picture. It also buzzes 3 times and the red and blue lights flash fast on front.
Something went bye bye. Check out your power supply for bad, burned components and/or blown caps - the latter often explode in their death throes.
Nov 03, 2015 | JVC HD-52FA97 HDTV
Service menu codes for P42H401 plasma
PROCEDURE:
(1) With Plasma turned On, Enter the I2C Service Menu: (Remember, you are doing this without seeing a picture).
  • Press "EXIT" once, just in case TV Guide is brought up for Set-Up.
  • Press "Menu" and wait a few seconds.
  • Press "Menu" ~ "Menu" ~ "8" ~ "Select" Buttons on the Remote:
  • The Service Menu is entered, even though you can not tell.
Service Menu selection you can not see
  • To navigate and adjust while in the Service Menu, use the remote control's Cursor Keys.
Dec 31, 2010 | Hitachi P42H401 42 in. Plasma HDTV
Following a audible pop TH 50PZ85U will not power on.
Most common thing to happen is a capacitor went bad on one of the circuit boards making the loud POP sound. Odds are it's on the Power Supply Board if the TV isn't showing power at all. The picture below what a bad capacitor looks like.
They range from different sizes and color. Swollen, deformed, and raised top is the thing to look for.
Solder in a new capacitor on the board or replace the whole circuit board.
Jan 30, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Hitachi p50H401 plasma - no picture no sound. blue led flashes
sound like mine,the two power clips have gone,midle panel to left,need to be replaced,if still no good,need new mother board with the clips.
Sep 26, 2009 | Hitachi P50H401 50 in. Plasma HDTV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
RCA SCENIUM HD50LPW166 worked fine, then "POP!!" has power
you lamp is bad. even if it looks good, its not firing (you're seeing the spark gap fire, indicating this). the lamp is customer replacable and roughly $200. the 5 blink error is a general shutdown error
Dec 08, 2008 | RCA HD50LPW175 50" HDTV
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
Hitachi P50A402 50 in. Plasma TV Logo
159 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
