Question about Nikon ProStaff Laser 440 Rangefinder
Unit "cannot measure" at any distance
Target cannot be measured at any distance. I have put a new battery in the unit and problem remains. The lens is not obstructed. The unit worked great for about four months after I got it and then it just quit measuring.
  • Anonymous Jul 14, 2008
    Laser finder worked perfectly for four months, then it just stopped giving distance, meters to yards button works. Press power button and three dashes are displayed.
  • KMAC1985 Aug 29, 2008
    Same thing... Used it very little last year. Then I just got it out this year, thought the battery was the problem, replaced it, and no measuring distance...
Had the same problem... Pushed the mode button and the power button simultaneously for 30 seconds, then it worked again...
Posted on Aug 29, 2008
Have golfbuddy wtx how to change yards to meters.
5.1 Distance : Unit of Measurement This setting allows you to change your distance measurement from yards to meters. The default setting is set to yards. ? The tab next to "Distance Unit" in the tools menu, shows the current unit of measurement that your unit is set to. To change from yards to meters and vice-versa, touch the tab, and then touch "Done" on the bottom of the screen, to save the setting. https://golfbuddyglobal.com/doc/usermanual_worldplatinum.pdf
Mar 07, 2018 | GolfBuddy GPS
Does not measure distance
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
Oct 18, 2014 | Leica Disto A6 Laser Distance Meter
Code error 279
Remove old batteries, put in new batteries, clean off lens.
Jun 10, 2014 | Leica Disto A6 Laser Distance Meter
Kodak carousel 760h projector
The auto-focus system in Kodak slide projectors is really an auto-measurement system: One set manually, the system is supposed to maintain that distance on all subsequent slides. Correct orientation of the slides is that they are all placed in the slide tray in the SAME direction (the matte side of the transparency facing toward the screen). The measurement is from the FRONT of the slide transparency to the BACK of the projection lens. REPAIR calibration of the system requires 2 special tools: a RANGE SLIDE and a TARGET SLIDE. These tool slides and the calibration procedure SHOULD be available from: www.micro-tools.com They purchased all remaining repair parts from Kodak when Kodak stopped supporting slide projectors. Good Luck !! Jim
Apr 30, 2014 | Office Equipment & Supplies
Why is it showing on the Screen info 206
Put in new batteries and clean lens and calibrate.
Mar 18, 2014 | Leica Disto A6 Laser Distance Meter
My nikon dtm 322 does not read distance above 100 meters.
are you sure about your instrument setting? you try press button "MRS1" or "MRS2", hold around 1 second n 1/5. Then at monitor come out "Target","Const","Mode","AVE" and "Rec mode". At "Target", u choose "prism". Good Luck.
Dec 10, 2013 | Nikon Dtm-322 3" Standard Total Station
Error Bosch DLR130 distance measurer
Same problem Err and --- on display. The front lens had become misaligned. Take off front rubber boot, clean lens and replace lens exactly in glue pattern on unit with rounded side facing out. Then holding unit with seated lens upright push rubber boot slowly back on. Very hard at first but push as much in by hand then use a narrow blunt point like the back of a screwdriver handle to press around the edge working it in with slow continuous pressure a quarter inch at a time. It will reseat just take your time and work the high spots. This time was not the batteries, works like new.
May 23, 2013 | Measuring Tools & Sensors
Always get error 279 on my Disto Classic
Put in new batteries and clean lens and calibrate if it has that function. If that doesn't work, Type the " Leica Disto A6 Laser Distance Meter user manual" and it will bring up sites to manual.
Jun 28, 2011 | Leica Disto A6 Laser Distance Meter
Unit is measuring cadence and heart rate, but is not measuring speed, distance or ride time.
Check to make sure your speed/ distance sensor is in alignment with your wheel magnet. If it is then check the battery in the sensor.
Speed and distance are on a different sensor than the cadence.
Apr 12, 2011 | Blackburn Neuro 5.0 Bike Computer
Unit puts out AC172v not 240vac,Setting
I think you measured the o/p voltage by digital multimeter which measure r.m.s. voltage that gives the wrong value measure the voltage by anolog miltimeter that meter shows the pointer and will gives proper value definetly upto 230vac
Mar 07, 2010 | MGE UPS Pulsar Evolution 1500 UPS System
Nikon ProStaff Laser 440 Rangefinder Logo
829 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
