Question about Nikon Cameras
How do I get the memory card out of coolpix? - Nikon Cameras
  • roobee52 Nov 08, 2008
    Now why didn't I think of that! Thanks
    Problem Solver:
  • 4 Answers
Try pushing the memory card in and it might pop back up
Posted on Nov 07, 2008
My nikon coolpix p2 camera says this memory card cannot be used, but it is a new memory card.
Have you formatted the memory card? When you buy a new memory card, you must go in your camera's menu and find the "format memory" selection and perform the format function. Once formatted by your camera, it should work.
Aug 08, 2013 | Nikon Coolpix P2 Digital Camera
I took the memory card out of my coolpix 4600 and put it into a vivitar camera when i inserted the memory card back into my coolpix cannot get the camera to work or turn off
Did you take pictures with the vivitar camera and saved it on the same memory card? If so, that might be the problem. Delete those files taken by vivitar (copy them to your computer if it is important before deleting) then try the memory card again on your coolpix.
Jun 16, 2011 | Nikon Coolpix 4600 Digital Camera
Is the memory card removale
Yes, the memory card is removable. The following web site gives different cards.
http://support.nikonusa.com/app/answers/detail/a_id/16778/~/approved-sd-cards---coolpix-s4000
The following is a list of approved memory cards for the Coolpix S4000 digital still camera. These cards have been tested and approved for use with the Coolpix S4000.
The S4000 uses SD (Secure Digital) memory. Memory cards with an SD Speed Class1 Memory of 6 or faster are recommended for recording movies. Movie recording may stop unexpectedly when memory cards with a lower Speed Class rating are used.
SanDisk 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 TOSHIBA 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 Panasonic 2GB2, 4GB3, 8GB3, 12GB3, 16GB3, 32GB3 Lexar 2GB2, 4GB3, 8GB31 Specification defining minimum data transfer speeds for SD and SDHC memory cards.
2 If the memory card will be used with a card reader or similar device, check that the device supports 2 GB memory cards.
3 SDHC Compliant. If the memory card will be used with a card reader or similar device, check that the device supports SDHC.
Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
Jan 06, 2011 | Nikon Coolpix S4000 Digital Camera
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Aug 09, 2009 | Nikon Coolpix 4100 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
I have a coolpix s230, using the memory card to hold pics
Try another memory card, memory card can go bad. If this does not solve the problem your camera has a fault in the SD memory card or the memory card board.
Jul 02, 2009 | Nikon COOLPIX S230 Digital Camera
Nikon Coolpix 4100 - transfer pictures to memory card
The easiest way is to transfer pics from the camera memory to you pc/notebook memory and then copy them to the the memory card thereafter with the help of a memory card reader.
May 15, 2009 | Nikon Coolpix 4100 Digital Camera
My nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Apr 28, 2009 | Nikon Coolpix S51c Digital Camera
No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
Jan 23, 2008 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
20 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
