Question about GE WBSR3140DW Top Load Washer
Waher washer wont agitates
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Please add more details. Does the machine fill? Make noise? (ie: motor running) Pump out and spin?
    President:
  • 512 Answers
First thing is belt broken? If not try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor.
Posted on Sep 23, 2009
  • 6,784 Answers
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cuase this dissruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitation components and clutch assembly as well.)))
Posted on Sep 18, 2009
How do I reset lg waher 1842cw it started stopped and now wont start
waher 1842cw? Have you looked at the trouble shooting measures in your manual yet? Check that first.
Feb 02, 2015 | LG WM-1832C Front Load Washer
Waher fill up but wont agitate
see this possibles causes: God bless you
see the diagrams
Lid switch
test the switch for open or defective with VOM see the diagram
Motor coupler
replace motor coupler
Belts
can be worn.
Clutch
clutch wear
Drive motor
one winding burn, one direction if for agitaten in another winding for spin.
Drive pulleys
worn replace
Transmission
worn or broken gear, +shifter defective
Agitator
worn and replace.
May 16, 2012 | Amana Washing Machines
Washer filled with water...will not agitate or spin or drain
You may have a bad or broken lid switch.The waher is thinking that the lid is open.
May 02, 2011 | Washing Machines
My GE wjre5550h1ww waher makes a continuos loud clank/bang noise when time the washer is in the soak/agitator cycle. Rinse and spine cycle, normal noise/sound. Please help! Thanks
The part (it has three prongs) that the transmission (yes your washing machine has a transmission) uses to cause the reciprocating motion of agitation has broken off 1 or 2 of the 3 prongs, and, if you
continue to use the washer (you might as well, the part is broken already - you may as well run it until it dies), the part will break completely, and you'll lose the soak/agitator cycle altogether.
FIX: replace the broken 3-prong plate, and give it a nice coating of automotive bearing grease to help it last for awhile (until the next thing breaks).
Dec 11, 2010 | GE WBSR3140DW Top Load Washer
Kenmore model 80 topload waher: does the agitator cap just pull off? don't want to break it.
cap pops off,remove pull up cover and find 7/16 bolt holding agitator to trans.
Sep 12, 2009 | Kenmore 22422 Top Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Kenmore front load washer will not agitate or spin.
try this unplug unit for 5 min.while unplug remove soap dispenser and reach way back there and move the flaper from side to side.then retry.God bless,tom
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Wont spin or pump out
these wahers are problematic and expensive to repair. remove whirpool emblem on front and remove 1/4 screw pull top foward and up look inside of front panel and you'll see tech manual
Dec 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
GE WBSR3140DW Top Load Washer Logo
125 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
