Question about Fargo Persona C15 Thermal Printer
Mag Verifying error
I get mag verifying error on all cards. Do i need service. or can i skip the verifying??
  • Anonymous Jul 31, 2008
    4250 thermal printer
    Novelist:
  • 114 Answers
Page 46 of the user guide suggests several things to try to resolve the error. http://www.fargo.com/users_guides_pdf/Persona_C16_Full_Document_(Rev.%205.0)1.pdf http://www.fargosupport.com/search_results.asp?printer=35&submit.x=16&submit.y=11
Posted on Oct 19, 2006
SOURCE:
3.5 Briggs ,new coil ,ground wire unhooked,no spark
Re loosen the magneto place business card between mag. And flywheel retighten mag mounting screws remove business card shine up flywheel with sand paper with the mag off the motor clean rust off flywheel before remounting mag with business card.
Apr 25, 2017 | Briggs Garden
Bakit ayaw mag power?
You can check if the power supply is still properly working by verifying if there is still light the power supply usually emits.
Should it not light, it could be that there is something wrong within the motherboard or the cmos.
Feb 28, 2011 | Computers & Internet
TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and F5 Mag Temp just began. They appear occasionally, now and then. Oven temp seems about right to me. What needs replacing or attention? Thanks!
the mag's only activate while in cook cycle, it will be hot as normal with toasted subs that are cold in the center.
AMP draw the Mag's and ohm the Mag thermal couples
Oct 14, 2010 | TurboChef TORNADO Electric Oven
Looking for parts & service: mag 10A cannon downrigger
Your best bet for price is looking on ebay, there are lots of links off of an inquire.
Apr 12, 2010 | MAG Cannon Mag 5 HS Downrigger
Ms-01410 error
Having exact same problem, cleaned everything, right settings, right cards, new head and still having ms-01410 and ms-01424
Mar 03, 2010 | Datacard SP55 Plus Printer
I recently changed from Preface to ID Works for printing my cards. At the same time I installed the Datacard printer driver ver 4.0 from CD. I have a SP 35 with and optional mag stripe kit installed. Now I...
Most likely your Mag-stripe info is missing from the card project in IDworks.
If you imported your projects from preface, its likly the box to include mag-stripe config was not transfer d.
enter idworks designer and click VIEW then field connections, there should be some info tied you mag-stripe field 1,2, or 3 of not there is the problem.
Next check printer plug ins in IDworks admin to make sure the mag-stripe plugin is installed. Also i would check Datacard.com Download section make sure you have newest and correct driver for your OS
if none of this works, uninstall everything (exporting projects) and reinstall.
Mag-strpe encoders can become defective, the encoder may need to be replaced.
Jan 02, 2010 | Datacard SP35 Printer
Fargo Persona C-15 error message "Bad Mag Option"
TRY RUNNING THE DIAGNOSTIC UTILITY AND ATTEMPT A MAGNETIC SELF TEST
TRY TO DO THE MECHANICS TO SELF REPAIR THE CLOGS AS INSTRUCTED
sangram.brahma@gmail.com
Dec 11, 2009 | Fargo Persona C15 Thermal Printer
Fargo Pro-L error message Mag Jam.
iT MEANS MAGAZINE JAM AS IN "MAGAZINE FOR CARDS"
May 29, 2008 | Fargo Pro L ID Thermal Printer
Ejecting CDs
The safest way to remove the cd mag is to take of the outer cover and wind the mech until the mag pops out
Regards
john
Oct 17, 2007 | Kenwood KDC-C465 6-Disc CD Changer
Fargo Persona C15 Thermal Printer Logo
381 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Craig Butler
Craig Butler
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
