Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Timing is off
If I had a diagram of how the machine should be adjusted to fix the timing, I believe I could fix it. Is this diagram available anywhere?
    Problem Solver:
  • 9 Answers
I checked my manual, and there is nothing about adjusting the timming. I'd call the White Co. at 1-800-331-3164 or go to www.whitesewing.com. Hope this is helpful to you.
Posted on Feb 02, 2009
Step by step how to adjust the timing on my empisal dress maker 270D
Search the internet for:
sewing machine timing
There are multiple web sites an videos available.
Jan 03, 2017 | Sewing Machines
I need to adjust the hook timing on my euro pro 361 and need to know how to adjust the needle bar
"sewing machine timing"
there are many web sites and videos available.
Oct 23, 2016 | Sewing Machines
How to fix timing on Kenmore 70 sewing machine
Try talking to the people at the link I attached. There are about 7 different adjustments to fix timing issues. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Feb 04, 2015 | Kenmore Sewing Machines
Need a blow up diagram of the timing parts for Shark Intelli-Sew Euro-Pro Model 9110.
I had a timing problem, I believe, and fixed it. But its not yet perfect.....What happened was the top thread was not being caught by the bobbin holder. So when I "sewed", there were no stitches. When I watched the bobbin through the window, the bobbin didnt turn, and thread didnt whiz around the bobbin holder as it should with each stitch. I even made a video to see if there was a timing problem...the needle went down well before the bobbin holder "thread catcher hook" arrived to catch the loop. So I took off the plate underneath the bobbin holder, and adjusted the timing. When you do that you will see a cogwheel that rotates as the bobbin holder rotates. Three alan wrench screws hold it tight to the axle that rotates with the handwheel/footplate. I loosened the alan wrench screws, and then did the following. Hold the needle holder so it doesnt move, and at the same time turn the hand wheel a little. This adjusts the timing of the needle relative to the bobbin turning. then plug the machine in, and see if the bobbin wheel is now catching the thread. Keep adjusting until it does. Then tighten things back up, and VOILA! Im not sure this is the best way to adjust the timing, but it works. My machine went from no stitches at all, to sewing nicely. Its not yet perfect, as it jams every now and then. But that may be because the timing is still a little off, or because the thread is bad, or the tension of the thread is not quite right......working on that still.......
Sep 11, 2012 | Sewing Machines
Same problem brother Ls 1217 thread will not catch
Whether the machine is front or top loading, the relationship between the needle and the hook is the key to timing.
Take a look at this and see if you can adapt it to your machine, the theory is the same.....the relative position of the needle rising 2mm with the hook just so.......the method of disengaging the main horizintal shaft and hook gear may be slightly different to this, so see how you get on.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Feb 17, 2008 | Brother LS-1217 Mechanical Sewing Machine
Bobbin timing
yes its still outta time. go back and make shure the pick up off the needle is set just right. otherwise it will continue to drop stites and break thread. ull know when u have it right it wiill sew as it should
Aug 17, 2007 | Consew 206RB
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
169 people viewed this question
Top White Sewing Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
