Question about HP Officejet J5780 All-In-One InkJet Printer
HP J8750 Cartridge error
Hello, I've got this big problem. My printer model is hp j5780. It's been a while and my printer is displaying this error message: "Cartridge error: Cartridge on right must be replaced." I've replaced it, refilled it actually and error message won't go away. I was looking for a way to reset the printer or something, but don't know how. Also, i was looking for a way to clean it too, but also don't know how. Is there any chance maybe if u know what to do?
Il really appreciate it!!!
I had this "Cartridge error" problem on my HP J5780 printer. Replaced the cartridge, but still got the same error. Then removed the cartridge and used a cotton swab with a little denatured alcohol, and gently and carefully cleaned the contacts in the printer. Followed this with a dry swab to be sure no alcohol left. Replaced the original cartridge, and have been using it for a week now with no more error message.
Casey K.
Posted on Nov 12, 2008
  • fatima1059 Feb 28, 2011
    THANK U !!!!!!!!!!!! ckassens
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Posted on Apr 05, 2013
Just got new catridge refilled and it only did two documents now says replace HP Office Jet J5780
Sounds like the refilled cartridge chip is not good, take back to where it was filled and get another cartridge
Feb 08, 2013 | HP Officejet J5780 All-In-One Printer
Can i refill officejet j5780
Yes it will not work unless you can reset the chip.
This WEB site can assist you in resetting the chip in the cartridge.
http://www.misterinkjet.com/hpreset.htm
May 20, 2012 | HP Officejet J5780 All-In-One Printer
Error and loud beeping
Hi Cathy, Unfortunately I am not familiar with the J5780 machine. Sorry I could not help. Kind regards Printdesigns
Nov 29, 2011 | HP Officejet J5780 All-In-One Printer
Hi Officejet J5780 all in one printer displays message 'Cartridge error' "cartridge on left must be replaced". Have replaced cartridge and also cleaned contacts but still the same....
Dear Ken, It is a logic card or sensor problem of your printer. In this cash better if warranty is there, take it to the service center. If no warranty, to any technician who can do it. thanks
Sep 03, 2011 | HP Officejet J5780 All-In-One InkJet...
My HP Officejet J5780 gives me an error code to change the left ink cartridge. We have done this twice now and still will not work. How come?
Hello.
On the front of the cartridge are some gold coloured dots, these dots line up with pins inside the printers cartridge holder. Make sure all these pins are lining up and free of any ink or dirt. Use a bright torch to make it easier.
I hope this helps Regards GM
Jul 15, 2011 | HP Officejet J5780 All-In-One Printer
I have a hp printer officejet J5780 All imn one.
I have found this model has a bad buildup of black ink in the right carriage bay chamber. With the printer on, open the carriage access lid and pull the power cord before the cartridge carriage can move all the way to the right side. Then gently push back the cartridge holder on the right if it's in your view, so you can see if there is a collection of black ink. The tri-color cartridge has a preventive bracket that doesn't seem to build as much as the black one. Anyway, once you've cleared any dripped ink cones or globs, plug the printer back in, turn it on, and if you get the Carriage Jam error one more time, press OK, and it should work well if that was the block on the carriage movement. I hope this helps you to get printing again.
May 04, 2010 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 all in one Alignment problem cartridge will still not align after I've gone through the alignment routine. Cartridges are genuine HP and fairly new
Usually the yellow is the culprit. Dab the cartridge on a paper towel and see if all colors make a spot or line. if any color is missing it will not pass alignment, and you need a new cartridge.
Dec 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Replace ink cartidge
Here is a link to the Setup Guide. Go to Step 5 for instructions for ink cartridge installation.
J5780 Setup Guide
Dec 07, 2008 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
1,271 people viewed this question
Ben Johnson
