Question about Dell 1700n Laser Printer
Printer jam on Dell 1700n
I noticed that you answered someones question about paper jams with the statement that if the paper is jamming at the back where it comes out of the printer that the sensor is either broken or dirty. I guess my question is this. . . I don't know where to look to clean it, but I will try. But if this sensor is broken . . .is it worth getting it fixed or just get a new printer?
Thanks. I really don't want to keep picking this 'fan style' jams out of the back of my printer. It is very frustrating.
  • Anonymous Nov 25, 2008
    My printer has a badly jammed page of paper in the back. I can't pull it out and I understand the problem is with the fuser. Is it more cost effective to repair my printer or to purchase another one?
The sensor is on the back of the fuser, it's the small black plastic piece that the paper hits as it passes through. (or is supposed to) online suppliers have this part for under $40 us. it's an exit sensor.
Posted on Nov 18, 2008
When printing i get the paper jam message have checked for paper jam but dont see anything
Open the cover on the back of the printer sometimes paper is stuck in there and thats why you can't see it.
Sep 29, 2010 | Dell 1700n Laser Printer
Dell 1700 printer paper jams
if the paper is jamming at the back of the unit, and looks like an accordian after removal, it's more than likely only the paper sensor on the fuser. i dont recall the part number, but it can be had from online suppliers for under $40.
Nov 10, 2008 | Dell 1700n Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Dell 1700N
We had a printer with the same problem, and turning the pickup wheels inside out (on the back of the paper tray) solved the problem.
Hope this helps.
Oct 19, 2007 | Dell 1700n Laser Printer
Dell 1700n paper jam
Most larger printers like yours have an optical sensor that needs to have the paper pass by in order for it to send the "sent" signal. If the paper doesn't trigger that you get the paper jam error. look at this page it will tell you what and where to check for your problem. It has photos and videos. I hope this helps some.
Sep 29, 2007 | Dell 1700n Laser Printer
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Jam trouble
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Feb 25, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1700n Jamming
try "rotating the pick up tires". (dell tech's phrase, not mine). pull the paper tray clear out of cabinet and look up inside the bottom of the printer. you will see a t shaped assembly with 2 large rubber tires (rollers). pull the assembly down (spring loaded) and peel the tires off the plastic mounting rollers. turn the tires inside out and replace them.
Dell 1700n Laser Printer Logo
161 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
