Question about Kenmore 63932 Electric Dryer
Dryer starts and then quits
Dryer will start and then quit after about 5-10 seconds. Motor starts to hum and there will be several clicks and then it will stop. The drum does turn. The dryer is a Kenmore Elite 63932.
  • justabum Nov 07, 2008
    Would that cause the motor to start humming loudly before it starts to shut off? It sounds as if it is laboring. I even held the door switch in and helped the drum turn by hand and it still started to hum and the shut off.
    Sergeant:
  • 229 Answers
You have a faulty heat safety switch. This switch prevents the dryer from overheating and causing fire. Some dryers have as many of 4 of these switches (seems redundant but it prevents fire) Depending on how confident you are with repairs the back of the dryer can be removed and the switches can be replaced. Most of them are circular and are found along the dryer exhaust area. I do recommend that this repair be done by a professional if you do not have allot of experience yourself because of the safety factors involved. Good Luck!!!
Posted on Nov 07, 2008
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
Whirlpool Dryer made loud humming noise and quit
Something caused the motor to lock up. The humming noise was the start winding in the motor trying to start rotation, but could not because of lockup. The humming noise stopped when the start winding burned out ( will only last 6 or 7 seconds). It will require a new motor, plus repair to whatever caused it to lock up in the first place.
Dec 22, 2013 | Dryers
Dryer motor hums ant wont start
Thais probably the motor but it might be something in the blower housing. Their are lots of movies on youtube that will show you how to do it. Now here is my home movie of a dryer like yours:
Sep 08, 2012 | KitchenAid Dryers
Roper dryer motor hums then quits after three seconds or so
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Dryers
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
I have a Kenmore dryer, mod 110 60956990, ser MJ4102370, type DDOT-ELE-2406028-EH54. When I push the button to start the dryer, nothing. If you wait several minutes, it sounds like it is trying to come on...
heatman101
Oct 28, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer door open turn select switch on starts to hum
I have fixed quite a few dryers and from what you say it sounds exactly like the motor is shot.
Aug 17, 2009 | Dryers
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 63932 Electric Dryer Logo
220 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
