Question about Orion STV2763 27" TV
Some channels have no sound some are in spanish
I have a 27 in. orion flat screen that is only 2yrs old suddenly when whatching tv lately i noticed that some channels are inexplicably in spanish and some have no sound at all i cant link it to my cable it is definately the tv if i auto prog to reset channels it randomly sets in different channels and the language is set for english on all channels the picture has been fine only last night it started saying text ch1 on channel 12 and after about 5 secounds a big black block appears switching off then back to the channel makes it go away for the 5 sec delay
  • amanda o'berg Oct 18, 2006
    thank you i couldnt get to that from the menu myremote has a button i didnt notice and it was on sap hopefully it is fixed ill be more careful that button is within me 5 mo olds bite!
  • Anonymous Jan 19, 2008
    I have the same problem, however, when I go to the menu, and audio, I do not have the option for SAP. I also have a universal remote that also happens to be RCA.
    President:
  • 3,130 Answers
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Posted on Oct 18, 2006
  • Larry  Dillon
    Larry Dillon Oct 18, 2006
    Great! Glad we could help!!
Had same problem, could not correct it with menu from remote. Pulled power plug for one hour, computer resets and can be reprogrammed when powered on.
Posted on Nov 30, 2006
The mts worked when not having SAP
Posted on Sep 26, 2009
If you don't have a SAP button it might be MTS, which is the same thing
Posted on Sep 21, 2008
4 Suggested Answers
SOURCE:
Shuttle83
  • 1139 Answers
SOURCE: Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
Posted on Aug 23, 2008
shawty-lozzy
  • 151 Answers
SOURCE: Problems tunning channels in my old orion tv
On the remote, is there a setup, install or menu button? sometimes its the red, green, yellow, and blue buttons on old tv's that are the tv's system settings, if that does not work can you tell me what the make of the tv is, there should be a number or make on the front of it.
Posted on Jul 19, 2009
DerStrom
  • 103 Answers
SOURCE: Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Posted on Apr 06, 2010
Hi, I have a 3yr old lexsor 27" lcd suddenly the
maybe the lcd screen is the defect already, lcd tv often use daily has a shorter life span compare to crt tv's. also there's possibility the inverter power supply of lcd screen has defect, or the connector is loosen
Feb 06, 2011 | Televison & Video
Orion 27" TV; Works ok
Turn off CCTV. Or Closed Caption. Several settings in the menu for CCTV. Just be sure they are off and your box should be gone.
Jan 17, 2011 | Televison & Video
Jul 19, 2009 | Orion STV2763 27" TV
Orion NOFTV2701 27'' No Volume Sound
I think my two year old grandson plug in the audio in cable into the earphone jack in front of the tv causing the problem. When my daugther unplug it the volume worked.
Thank You aragon1234
Mar 07, 2009 | Orion STV2763 27" TV
Orion tv problem
tv flipping colors and verticle alignment not straight
Jan 19, 2009 | Orion STV2763 27" TV
Channel reduced
On the STV2763, go into the ch set menu and change it from tv to catv.
Dec 20, 2008 | Orion STV2763 27" TV
No display on Sharp LC 32sh20u
blue screen,no video but has sound
Dec 18, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
My toshibia model 27d46 tv will not turn on
Toshiba flat-screen digital SDTV, 27", won't turn on. Was difficult to turn on for awhile, but some channels had no sound, others that were in English usually, would suddenly turn into Spanish language. A loud static noise would occasionally come on, and then go. TV just won't even turn on now. Is there any possible repair that would be less expensive then replacing the set? I can't lift the set,as it is much too heavy. I'm a senior, and I'm strong, but not that strong.
Dec 13, 2008 | Toshiba 27D46 27" TV
Black square appearing on tv
turn off closed captioning
Nov 29, 2008 | JVC AV-27530 27" TV
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
Orion STV2763 27" TV Logo
1,951 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
