I have a technics A900 mk2 amp powering two b&W speakers. never had a problem before until i moved the room round and hence the speakers and amp. Now the amp cuts out whenever i turn the volume up past a quarter on the dial. Have tried all combinations of switching the speaker cables round still no joy. Any ideas
  • Anonymous Apr 27, 2009
    Exactly the same problem here!
Hi guys, I have the same problem and been going crazy looking for a replacement fan motor. This is the problem. THESE LITTLE FECKER fans have micro chips inside and cost over 80 euro. They fail and there are NO replacements anywhere. I have emailed everyone from Technics to Panasonic to Matsushita, who actually used to make the unit. NO LUCK! Soooo frustrating.
Anybody know how to bypass this?
Posted on Jan 31, 2011
  • 4 Answers
Look at you fan ;)
Posted on Oct 31, 2010
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: i have a technics A900
To confirm the status of the amplifier to be in order you can use an headphone to test . Now connect a valid input and open up beyond the quarter mark the volume to see if there is any cut off.
If there is a problem the amplifer must be checked, First of all check if the input supply voltage in the phase is lower than in the earlier outlet as a low supply can cut off supply on loading.
If this is correct the speakers must be checked separately for the impedance, if there is any short in the speakers wires or in the connection area.
If there is no visible errors seen the amplifier could have acquired some errors while you moved.
Check once again the input: if the source input is connected to the same input or else a higher input can cut off due to load current. Check with a separate input source.
If these test are good , then you must recheck once again the input voltage settings on the amplifier.
Finally check after opening the covers to fix all connectors to be tight.
Since it worked before it was moved it can be some accidental errors . If not a coincidence of an amplifier failure must be checked only if there is distortion in the output.
Check main +B voltage to the power amplifier.
Posted on Oct 27, 2010
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
My Technics SU A700 mk2, doesn't have any signal in right channel. During (i am first owner)time I noticed that I had that right channel performance reduced arround 15% compared with the left one. ...
Have you tried cross-plugging the speaker cables (i.e. swapping left and right channels) to be absolutely sure it is the amp ? I have a speaker that needs a fair amount of volume to wake it up, but after that performs well.
Jun 15, 2017 | Cameras
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
Sep 16, 2011 | Alesis Monitor One Mk2 Speaker
Jvc rx 703b repair--I was playing on a technic sl mk2 turntable made a loud noise then went out on one speaker then later the other
Hello
Your Amps' output section has shorted. Don't connect any other speaker to it, till it has been repaired. It will burn out it too. In some sets this section will be of transistors, and in others, an IC will be used. Anyway it has shorted and has to be replaced. OK.
Apr 19, 2011 | JVC Audio Players & Recorders
How do i go about connecting the alesis monitor one mk2's to my my laptop? i do not have an amp and there are no cables or connectors with the speakers when they arrive
You can without an amp in between. They are non-powered speakers and need an amp to drive them. If you connect your laptop to a mixer, mixer to an amp, then amp to speakers THEN they will work.
Feb 19, 2011 | Alesis Monitor One Mk2 Speaker
Technics a900 mk2 amplifier cut out sound to speakers.
First of all, Marcus, you will need to check if you have blown off the speakers. Just remove and use a good 1.5 AA cell to test both the speakers. If ok connect and switch on. try to hear if the relay is clicking or if you hear any noise. If not disconnect, open the set and use a multimeter to check if the output had failed. Check on the sections only if your are familiar working with circuits or else it might not be recommended. Get help from a friend to check the protect circuitt and the main board for failure of the mosfets/ outputdrives. If you can reset the amp do so by keeping the menu pressed on swithed on. or keep it off for anout 12 hours. it will reset on its own. I hope this helps. Good day
Jun 11, 2010 | Technics SUV500 2-Channel Amplifier
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
My technics su-a900 mk2 keeps blowing the internal fuse
Sorry but it sounds like a problem with the power supply unit.
Look for any 'burnt looking' resistors on the printed circuit board and that should give you a major clue!!
Nov 22, 2008 | Technics Audio Players & Recorders
Mk2 speakers
is it the m1 active mk2???if so try changing the fuse in the power supply..i know my ones the light started to flash on one,i switch it off with a fan on it for 20 mins and it works again..so i just leave it on now.
Oct 17, 2008 | Alesis Monitor One Mk2 Speaker
Hercules mk2
whats the type of your console's motherboard ?
Dec 22, 2007 | Computers & Internet
304 people viewed this question
 Grubhead
Grubhead
