Question about Dell Vostro 1500 Notebook
Laptop Won't startup Vostro 1500
Get a flashing lock symbol on my keyboard apon turning my laptop on? The lock has a A in it. The laptop won't boot up?
Please help me
  • 9 more comments
  • marianne87 Nov 07, 2008
    Hello
    It won't work. The lock symbol is still flashing
  • tbagave Nov 10, 2008
    I am facing the same issue. I have a vostro 1500. When I press the power button the laptop doesnt start. Please let me know what needs to be done.
  • longjohn1 Nov 10, 2008
    hi sorry i posted this in the solution section:
    hi there i have the same problem, a flashing lock symbol with an A inside it and i have tried the method to get in to the psa but it won't do anything just keeps flashing and then turns off. Any help would be greatly appreciated. laptop has been back to dell twice but they say its working fine with no problems. mine is an ispiron 1520. tried everything i can think of but nothing works so far. Please help. :)
  • Anonymous Feb 24, 2009
    Have a locked symbol with an A next to it; nothing will respond on laptop; what can I do
  • pshah704 Apr 03, 2009
    Blue lock key is on. Laptop wont start. I have tried walters soultion still no luck
  • tmoore85749 Apr 13, 2009
    Computer won't start up I get a lock-up with a flashing A same as the others reported
  • jkkarteek May 12, 2009
    Dell Vostro 1500 wont boot up when I press power button only caps lock button blinks.
  • Anonymous May 21, 2009
    I had the exact same problem and the solution below worked!
    thanks a lot!!!
  • posthuman May 11, 2010
    THANK YOU walterb_8 ! I registered just to express my gratitude, because I found your solution after searching the web. I had the exact same problem and your solutions fixed them. Now the laptop runs perfectly as always. It died at a very bad time when I needed it the most and I was frustrated, but thanks to you, everything is fine now. Thank you !
  • Mark Ward Sep 19, 2013
    I have tried all tgese methods but to no avail. My worry is that the computer has all the family photos on it!
  • Anonymous Mar 31, 2014
    I have tried searching for solutions all over and have had no real help in the matter so far, I can't afford to replace the PC anytime soon and need help.
  • Dell Master
  • 998 Answers
See if you can run the Pre-boot System Assessment (PSA) diagnostics. To run the PSA+ Diagnostics on this system, perform one of the following actions:
1) Hold down the <Fn> key while pressing the power button.
2) Turn on the system, press <F12> at the initial Dell™ logo screen, and select “Diagnostics” from the boot menu.
3) Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message “Diagnostic boot selected” displays. The system then launches the PSA+ Diagnostics.
According to Dell specs, there is no error code listed that you described, (Flashing Caps LED). Also try reseating the memory modules, (you might want to try this first).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 07, 2008
  • Walter H Boehm Nov 08, 2008
    If it's still under warranty, call Dell for repair or use FixYa's Repair Directory to locate a repair shop in your area.
  • dukedms Sep 02, 2011
    Walterb_8, Thank you. I re-seated my memory modules and was able to re-start. I dropped my notebook the other day and it must have jarred one of the memory modules loose. Thanks again, Dan
Hi there i have the same problem, a flashing lock symbol with an A inside it and i have tried the method to get in to the psa but it won't do anything just keeps flashing and then turns off. Any help would be greatly appreciated. laptop has been back to dell twice but they say its working fine with no problems
Posted on Nov 10, 2008
  • thy chalz
    thy chalz Jan 19, 2013
    Had the same problem with the flashing lock; Tried removing the RAM from below the laptop system unit, same thing then tried to remove the RAM just below the keyboard, the laptop started booting n working now. First take out the cover for power button. Than remove the keyboard, u will find another RAM just there.
Laptop Won't startup Vostro 1500 - 7_13_2013_10_21_14_pm.jpgI I just solved this problem today. Try to change and switch / unplug your ram and your battery , just use normal power supply and the the best is detach your hard drive out and pull out the interposer which attach to the SATA hard disk and put it back. This solutions work for me.
Interposer - image above
Posted on Jul 13, 2013
Posted on Jan 19, 2013
The problem is the video card. The card cost $150 plus labor to install it. There is temporary fix to it .First take out the cover for power button. Than remove the keyboard. Take a hair dryer from home,use high heat blow it into the video card about 5 minutes.The video card is on the right side of the power button. Than put everything back together and restart the laptop. This work for me. Good luck....
Posted on Nov 27, 2012
Most times it lights battery light only
wont boot
Posted on Dec 30, 2009
Vostro 3500 won't turn on and charger light is flashing
How old is your laptop? if it is over 5-6 months it could be because of a faulty battery. You may want to upgrade or change your battery.
Apr 10, 2013 | Dell Vostro Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
Hi i have a vostro 1520 dell laptop there is a problem that some strange 1.my laptop when just full battery is connected to it won't turn on but when i press 20 to 30 sec the turn on key and...
First 2 of your problems are due to the fact that your laptop enters hibernation (or hybrid sleep in windows 7) and windows cannot restore your last saved state. The 3rd problem indicates you have windows problems (bad/not updated drivers, filesystem corruption, application issues). I would suggest you to reinstall windows.
May 14, 2011 | Dell Vostro 1500 Notebook
My dell vostro 1500 laptop doesn't boot up the battery and ac power source is fine, what happens is that the only light or noise that comes form it is that the caps lock blue light indicator flashes for...
it sounds like your ac adapter has burned out and won't charge anymore. That's very common... that's why they are so cheap on ebay. Either that or your power plug on the motherboard is cracked or loose at the motherboard (2nd most common) and last bad motherboard (don't assume this unless last resort.)
Jan 12, 2011 | Dell Vostro 1500 Notebook
On boot up a lock symbol with a '9' is lit & nothing else happens
the "9" inside a lock means that your Num Lock button has been pressed. If all you see is the ">" then maybe you are looking at what's called a DOS prompt, and I have no idea why that would display. Try holding the Power Switch for 10 seconds and restart your computer. Hopefully things will be better, and you know where your Num Lock key is.
Oct 10, 2009 | Dell Vostro 1500 Notebook
My Vostro 1500 will not turn on anymore...help please!
Reset/replace the Ram/memory. Sometimes faulty and failing ram can keep a computer from booting up. If you have 2 sticks, take one out and then try to boot, then try with just the other stick. The flashing caps lock icon means a general failure, though it is most commonly associated with the motherboard.
Jun 25, 2009 | Dell Vostro 1500 Notebook
How to fix flashing lock with A in it computer won't boot up vos
The flashing CAPs Lock is an indication of a MEMORY error. Try Memory modules one at a time, and see if the system boots with one module or the other. If it does, then replace the faulty module. If system will not post with either module, replace motherboard.
Laptop won't startup
Try removing your battery and then putting it back. If that doesn't work, then either your hard drive is bad or maybe even your motherboard is bad. If you can get into your computer's BIOS, check and see if it will allow you to do a system restore from the BIOS page. As stated above, it is probably that your hard drive is bad.
Sep 06, 2008 | Dell Vostro 1500 Notebook
Vostro 1510
Possible memory issue. Try Reseating your memory card on the system, it would be helpful.
Dell Vostro 1500 Notebook Logo
10,068 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
