Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Kitchen Aid switching from mixer mode to grinder
I dont have the instructions on how to switch from the mixer mode to grinder.
  • 118 Answers
There is no switch. When you have the accesory in the front, the beater section still moves. I suggest that you remove the beater so that there is less possibility for someone to get hurt.
Posted on Nov 30, 2008
When I switch my mixer on it goes to full speed
If it is a Kitchen Aid mixer I would suspect the little pcb with 4 wires coming out of it under the rear cover at the top.
If it is not a Kitchen Aid you will need to supply more clues.
Mar 21, 2015 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
I have a kitchen aid 5 at. Mixer when I use my grinder attachment I notice oil/ grease on shaft what is that caused from
Sounds like a problem with the bushing around the accessory drive. If still under guarantee take it back and get it sorted. If out of guarantee take it to an authorised service centre.
Dec 15, 2014 | Food Mixers
Kitchen aid model kb25gixob will not turn on.any suggestions?
Put an ohmmeter across the two pins on the plug, on the mixer,,not the earth one.and turn the switch on.you should get a reading,plus it will change as you turn the switch to different settings.if no reading,suspect broken wire in plug,or mixer windings burnt out.try in a different socket
Sep 12, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid switch not working
Which switch speed or head lock? What are the problems? Need more info to help.
Sep 07, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
Bad switch on kitchen aid mixer
Unfortunately you will probably need to split the gearcase to sort out the speed control arm.
Nov 30, 2012 | KitchenAid Kitchen Aid Mixer Stainless...
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
KitchenAid Mixer
depending on the model there is a round cover on the front of the mixer. Detach it to expose the secondary drive connection. Depending on what you are connecting to it you need to connect to the drive port and secure the accessory so it is stable. If you need instructions google kitchen aid and ask them for a manual.
Mar 19, 2008 | Food Mixers
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
95 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
