SOURCE: how do i demagnatise my color screen
HI ,you have to purchase a DEGAUSSING COIL , item can be found in one of the major AUCTION SITE , they can cost you around $20.00 / less or more . once you have item ,hopefully the instructions will be included , but basically what you do is to put the DEGAUSSING COIL in front of the screen and do circular motions where area affected and slowly move away from the screen until the spot disappears. hope it helps
SOURCE: picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
SOURCE: Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
SOURCE: 1992 RCA color trak tv
Rca used channel 91 as the a/v input on my 1990 colortrak,yours should be the same.
SOURCE: Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
