Question about Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset
Compatability bluetooth headset K 750i/K800
I have just bought a K800 and the Sony E bluetooth headset I had for my K750i doesn't seem to work with the new phone. It doesn't recognise it. Can someone please tell me how to get the right "light" configuration on the bluetooth h/set so it can recognise it as a new device. the Telstra guy couldn't do it and told me I needed to get a green/red flash happening before it could "add device".
  • Anonymous Jul 20, 2008
    I had exactly the same Problem with the same solution!
Hi, The way that I paired my device is by pressing and holding the two volume buttons simultaneously for about 5 seconds, until the red and green lights began to appear. Then, i just 'refreshed' my bluetooth search for devices, and it discovered it, and was able to pair it up. Hopefully, this is useful
Posted on Aug 02, 2007
Its worked for me.... thank you
Posted on Feb 07, 2008
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Is there a free way or calculator i can use to unlock a sony ericcson k770i please?
no calculator but i can help you unlock it for free .....
have a look here http://forums.se-nse.net/topic/20668-who-wants-to-unlock-k800-db2020-cid52-for-free-with-supplied-dcu-60-cable/
that shows a k800 but your k750 would work the same way except you would not have to bypass security.
also are you aware that a k750i can be flashed to a w800i?
tutorial on that is here: http://forums.se-nse.net/topic/3996-k750i-to-w800i-via-seus-and-dcu60-for-free/
personally if it was me i would flash the phone to w800i then unlock it, in fact i have down that as i used to have a k750i and so did a mate of mine which i also did same thing
Apr 03, 2010 | Sony Ericsson K750i Cellular Phone
Can i pair k750i with HBH610a?
Yes. I have this old trusty combination and it works perfectly with auto-pairing. The phone also supports bluetooth v2.0 which means good sound quality and excellent link reliability.
Check out the instructions here: http://www.sonyericsson.com/cws/support/accessories/detailed/userguide/hbh-610a?lc=en&cc=us
Mar 24, 2009 | Sony Ericsson HBH-610a (Auto Pairing)...
Sony Ericsson not recognising motorola n356 headset re bluetooth.
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 23, 2008 | Motorola Mobility Bluetooth Hands Free...
Pairing bluetooth
First you have to check if the bluetooth is universal or works with your mobile phone; if it does then it could be that your phone has been set not to be visible to any device. You can change that by going to the bluetooth settings or option and change the visibility setting.
Dec 13, 2008 | Sony Ericsson HBH-610a (Auto Pairing)...
Please need help urgently
You should press both + and - button on your head set and wait until green light turns into red.
May 13, 2008 | Sony Ericsson HBH-PV705 Headset
How to add bluetooth head set HBH-iv835
yea how ya goin mate its simple i had one of them, just go in your menu go in your bluetooth setting and search for device but make sure your head set is on and fully charged
Mar 29, 2008 | Sony Ericsson K800i Cellular Phone
How to play music though your sony ericsson k800 bluetooth headset
Your bluetooth device will be for one ear, yes! you have to connect the hands free headset to your phone, for the radio it acts as an aerial, the ear pieces for the stereo.
Feb 24, 2008 | Sony Ericsson K800i Cellular Phone
Sony erricson 750i
it seems to me you havent damaged the battrey so that means you must of damaged the soft wear that programs the screan
Feb 22, 2008 | Sony Ericsson K750i Cellular Phone
Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset Logo
183 people viewed this question
Top Sony Ericsson Radio Communications Experts
Håkan Sterner
yobo007
yobo007
Jay Finke
Jay Finke
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
